993 rod bolts
If my memory serves me correctly, 993 rod bolts are not stretch bolts like earlier engines. They do not have to be replaced if the measurement of the bolt from the base of the rod cap to the end of the stud does not exceed 38.3 mm.
3 knurl bolts can’t be replaced, but 4 knurl can. So, if you measure less than 38.3 mm then you are good to go with either style rod bolt, is this correct?
Thanks in advance.
Old 12-11-2022, 03:52 PM
I wouldn’t trust original bolts. Use ARP or like aftermarket bolt. G
Old 12-11-2022, 03:57 PM
Agree, replace / upgrade
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 12-11-2022, 07:03 PM
ARP it will be
Old 12-12-2022, 10:22 AM
Something you need to do when upgrading to ARP bolts is that the big ends will need to be resized due to distortion from the added torque.
Old 12-23-2022, 08:14 AM
