Carmagic.us
rothaus's Avatar
Got my Camshafts back from repair/regrind
I got my 964 camshafts back from repair and regrind. Is this normal what they look like ? I expected them all shiny like polished.
Engelbert
For BA7s Dash LED, and External Marker LED go to carmagic.us - Now Luftgekühlt Emblems
Old 01-03-2023, 08:10 AM
That's what they look like when I get them. Have had several sets now.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 01-03-2023, 08:55 AM
I asked John D. about this. He said special coating, don't remove prior to install, but verify for yourself, quick call does it.
Old 01-03-2023, 09:38 AM
It's a 914 ...
stownsen914's Avatar
I got a set of cams back from Elgin that had a similar look. He called it Parkerizing. Apparently it’s for corrosion resistance and lubrication. I assume it’s sacrificial.
Old 01-04-2023, 03:45 AM
Carmagic.us
rothaus's Avatar
That is the answer I got.
" phosphate coating is for break in "
Engelbert
Old 01-04-2023, 05:15 AM
Surface Texture............
Engelbert
Engelbert,
From the above pictures, cam 1-2-3 specially for cylinders #1 and #3 don’t look as good as the cam 4-5-6 lobe surfaces. They should even look smoother but not shinny with the protective coating.
Did you send a close up pictures to your cam rebuilder? I have used cam shafts looking much better than these one. These are not defective cams per se but won’t be happy to have them as they are.
Tony
Old 01-04-2023, 05:32 AM
Tony,
Once the passivation layer is removed they are all good. Mine looked like that, 20k miles since and they look great.
Phil
Old 01-04-2023, 06:36 AM
superninety's Avatar
I had Dema Elgin do my 964 cams. Looked exactly like that.
I just had him do a custom grind for a 3.2 build. Same look.
Robert Callaway
PCA | Early S Registry | R Gruppe
1970 T Coupe, 1990 C2 Coupe, 2007 Cayman S
1962 S90 Coupe - Gone, but never forgotten...
1985 Targa - A distant memory...
Old 01-04-2023, 07:36 PM
Carmagic.us
rothaus's Avatar
Thanks for all the feedback !
Old 01-06-2023, 01:24 PM
