-   -   Wire identification (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1132929-wire-identification.html)
ed decker 01-14-2023 04:58 AM
Wire identification
Can anybody help me identify theses two wires. They are located behind the gauges near the master cylinder. My brake lights went out and rear turn signals. Also emergency hand brake light came on. I noticed these two wire shredded maybe by a mouse I can not find a place they connected to maybe the yellow connector but doesn’t seem right. http://forums.pelicanparts.com/uploa...1673700993.jpg
timmy2 01-15-2023 12:22 AM
The receptacle side comes from your brake master cylinder wiring. The plug side that has chewed off wires comes from the through body harness where the yellow wire for the starter solenoid connects.
Brown/White runs to the handbrake switch in the through body harness.
Black Green is the power to the brake lights and runs through the same harness to the passenger tail light plug, then back over to the driver’s tail light plug.
timmy2 01-15-2023 12:25 AM
This is from an 82, but yours will be similar.
http://forums.pelicanparts.com/uploa...1673771096.jpg
ed decker 01-16-2023 03:41 PM
Thank you very much.
Ed
ed decker 01-16-2023 03:42 PM
Everything works now.
timmy2 01-18-2023 09:27 AM
Great, but what did you have to do???
May help others in the future…
