3.0L Distributor Drive Gear
How is the distributor drive gear held on to the dizzy on a 3.0L from an '81SC? Does it use a split dowel pin? Just a regular ol' pin? A hex socket headless bolt? How easy is it to tap out and press in - Does it just "fall out" or am I gonna need to use some force?
http://forums.pelicanparts.com/porsche-911-technical-forum/1114917-jedi-911sc.html
Old 02-10-2023, 12:56 PM
That copper coated pin is just a pin that gets peened. That’s what you get when you order a new one from Porsche. I’ve seen them with roll pins as well. They uninstall and reinstall pretty easily
it's not leaking....it's just marking it's territory
Old 02-10-2023, 01:32 PM
Gordo2's Avatar
Distributor Disassembly
Pin can be difficult to remove - I had to drill mine out.
Here's some info that may be useful:
83 SC Ignition Distributor Bushing Replacement
Good luck
Don "Gordo" Gordon
'83 911SC Targa
Old 02-11-2023, 08:55 PM
