-   -   gasket set questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1134444-gasket-set-questions.html)
hermanator 02-07-2023 04:40 PM
88 carrera rebuild. Would you go for the wrightwood copper base gasket or try the reinz
new black coated gaskets? does anyone know if the reinz set comes the rsr seals?
tks for any help
Zuffenwerker 02-07-2023 07:16 PM
Reinz set does not come with rsr seals.
hermanator 02-08-2023 08:49 AM
Thanks zuffenwerker.....
PeteKz 02-09-2023 12:58 AM
I swab a little bit of Permatex Ultra Black around the copper gaskets before I torque down the heads. Haven't had leaks yet.
Cevan 02-14-2023 11:01 AM
I just got the Wrightwood Racing gasket set. It did come with the RSR seals.
It also came with a mystery red o-ring and this chrome covered plastic thing. Any idea what they are?
The o-ring is 20mm ID by 2.6mm and the plastic thing is 50 ID x 63mm OD.
http://forums.pelicanparts.com/uploa...1676401267.jpg
Flat6pac 02-14-2023 01:48 PM
The big one is probably for the early two piece crossover ear pipe
Bruce
hermanator 02-14-2023 02:39 PM
red o-ring appears to be distributor. collar not like anything on my 3.2.
tks for the info on rsr seals.
Flat6pac 02-15-2023 08:16 AM
The dist seal is thicker and is tapered
Bruce
Cevan 02-15-2023 03:37 PM
Definitely not a dizzy sea. There was one included.
