-   -   3.6 rebuild/refresh/reseal (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1134889-3-6-rebuild-refresh-reseal.html)
Jeff Burger 02-15-2023 08:27 AM
I am nearing the completion of the original motor for my stock high milage 92 964 street car.
In the past when I rebuilt 3.6 motors for my race car I never replaced the engine surround covers that hang from the engine sheet metal over the bottom part of the motor. All the covers I now have in my spares have the foam crumbling and falling off. I would scrape it all off before using on the motor leaving the plastic with the silver outside covering .
1. I see a lot of reasons to leave them off on this motor . Any recommendations to put them on and the reasons to do so other than originality and maybe a little sound reduction.
2 If I do decide to use them, does someone have a recommendation for replacement foam or will they be fine without any foam.
http://forums.pelicanparts.com/uploa...1676477877.jpg
Flat6pac 02-16-2023 04:41 AM
Jeff, From what I’ve seen of C2 sheet metal you’re lucky to draw a magnet on any of it, much less with foam on it.
Bruce
Jeff Burger 02-16-2023 05:37 AM
thanks bruce at least I know someone saw the question. I have seen some pretty rough pieces of 3.6 sheetmetal myself however these are in nice shape and were blasted and powder coated. It is the vertical plastic side sheilds that I am talking about.
