Diving in 911
964 case cleaning question
On the main journals how aggressive should I get on cleaning them? Should they be clean and bare? Green sponge and acetone on the sealant residue. I just don’t want to get into the material. Any suggestions and guidance would be appreciated
1976 911s Special Edition Turbo bodied IROC tribute
2002 911 Carrera C4S
1971 914 1.7 Tangerine
1989 964 Coupe/1992 964 Cab
1987 928s4 Granite Green / 1986 951
Old 03-14-2023, 12:25 AM
It's a 914 ...
stownsen914's Avatar
Definitely want all sealant off, but definitely also don't want to remove any metal. Sounds like you have the right idea on cleaning materials. I go through a few plastic scrapers on an engine rebuild/cleaning, they dull quickly.
The surfaces on those webs may look a little funny even when completely clean due to the fretting (rubbing) that happens during engine operation.
Old 03-14-2023, 05:27 AM
Yeah lots and lots of time with little plastic scrapers. Leave those machine marks on the webs, your cleaning, not polishing, not removing any metal, unless there is some random ding or scratch leaving "high metal" you would want to remove local areas of high metal (the metal displaced by a scratch or ding.
I used some aircraft paint stripper on a cotton swab on bits of sealant that gave me trouble. Didn't use it much but just on the tough spots.
It's hours and hours of fun.
Old 03-14-2023, 10:37 AM
When cleaning main journals, it's important to be thorough but also cautious to avoid damaging the material. A green sponge and acetone can be effective for removing sealant residue, but it's important to use gentle pressure and avoid scrubbing too aggressively. It's also a good idea to test a small, inconspicuous area first to make sure the cleaning method doesn't cause any damage or discoloration to the material. Ultimately, the main journals should be clean and free of any debris or residue that could interfere with their function, but it's important to take care when cleaning to avoid any unintentional damage. I hope this will help you. upsers
Old 03-14-2023, 10:46 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
If by "green sponge" you mean scotch brite pads, do not use them. They will remove case material.
1986 Targa Guards Red
2021 MT09 SP
Old 03-15-2023, 04:34 AM
Diving in 911
Green dish sponges
Old 03-15-2023, 09:45 AM
It's a 914 ...
Good point about not using abrasives. Better to find the right chemicals to soften/melt the sealants (while not hurting the case) and work at it as needed with rags, plastic scrapers, or other non-marring tools.
Old 03-15-2023, 01:21 PM
Diving in 911
Thanks all!
Old 03-15-2023, 03:18 PM
Have you measured your main bore?
Bolt the case together, mount the #8 nose bearing, and torque your through bolts and run a bore gauge and let us know how it measures.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-18-2023, 12:30 PM
Diving in 911
Case went out to my machine guy, checked out fine. It has less than 70k miles on it. Only reason it had to come apart was it sat for 20 years in a wrecked car that it didn’t know.
Old 03-18-2023, 03:05 PM
PCA Member since 1988
Then reuse the main and rod bearings if they are not scored or worn. That's not just to save money, those bearings have already stood the test of time. I don't know about the 3.6, but some replacement bearings for the 3.0 and 3.2 engines have had problems with fit and the fine points of construction. If you have known good bearings, keep using them.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 03-20-2023, 12:27 AM
