-   -   Nose length dim's 964/993 & GT3 crank, same? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1136109-nose-length-dims-964-993-gt3-crank-same.html)
JoeMag 03-06-2023 10:09 AM
Is this dim the same on a 993/964 and a GT3 (non-4L) crank?
http://forums.pelicanparts.com/uploa...1678126135.jpg
JoeMag 03-07-2023 08:57 AM
...actually what I'd like to know is if someone has a Gt3 crank, could you let me know what this dim is?
356RS 03-08-2023 07:56 AM
You will most likely get an answer before me but I will get measurements off my GT-3 crank and post it today.
356RS 03-08-2023 10:21 AM
I get close to 67mm. My GT-3 crank is not tapered at the end like yours.
JoeMag 03-09-2023 09:58 AM
thanks...
targa72e 03-10-2023 01:40 PM
I have both a GT3 and 993 crank to check.
These are the only numbers I could find on GT3 crank.
http://forums.pelicanparts.com/uploa...1678483688.jpg
My snout is not tapered either.
http://forums.pelicanparts.com/uploa...1678483725.jpg
GT3 Length. 2.63"
http://forums.pelicanparts.com/uploa...1678483747.jpg
993 crank snout
http://forums.pelicanparts.com/uploa...1678483849.jpg
993 measurements 2.65"
http://forums.pelicanparts.com/uploa...1678483888.jpg
I also measured a 3.2/3.3 crank for comparison. 2.29"
http://forums.pelicanparts.com/uploa...1678484158.jpg
I believe Rothsport makes crank pulleys with the correct offset for later cranks in earlier cases.
john
JoeMag 03-10-2023 02:32 PM
Thanks for breaking out the collection John...
The 964 crank in the pic measures 2.65". Look'n at your pic, the GT3 measurement might have been on the radius a little as I believe the 964/993/GT3 have same nose length after some other side conversations. Neil noted to me that the later longer noses are 0.35" longer which corresponds to your 3.2 measurement too.
