Cam recommendations for present build
Looking for the best cam profile for present build.
3.0 small port heads 9:5 Je pistons 40mm carbs Backroad driving mostly Wondering what this M cam is all about. |
I have 'em. I like 'em. They give a good combination of low RPM torque and high RPM power. I don't have a lot of experience with different cams in 911's though. I know that with my CIS 3.2LS engine, I can floor the pedal at 1300 RPM and it pulls cleanly to the top of the rev range. Now, as a matter of good mechanical practice, I don't usually floor the pedal below 2000 RPM, but it shows that the combination of M1's plus CIS is very drivable across the rev range, which is what I like for a street driven car that isn't a high-RPM track car. It also gets close to 30MPG at 70MPH cruise.
With 3.0 small port heads and 40mm carbs, I think they would work very well. Let's wait for Ian to weigh in, because he helped William Knight develop the cam. |
Hmm.. The verdict is still out with me. The M1 is very smooth at idle, so smooth it shows off the unbalanced fuel distributor, so the FD is out getting rebuilt by the pro's because when I tried to do it it still leaks just a little bit, but enough for you to smell it so that is enough to turn in to a car b que.
Hope to be back flogging the mule soon. |
So smooth at idle! It's not rowdy at all. The M1 is a great bump in performance without any real downfall.
Sorry I am sick as a dog
DP is using JE pistons, this opens up the cam choice tremendously . For a 9:5/1 comp ratio , I think the most fun will come from a Kight Race. 45 Ill get back to you all later Ian |
Dpmulvan: Curious, why are you picking the JE pistons?
Post the cam specs [lift, duration, lobe center] and I'll tell you what I think.
Just off the top, if the cam works well with a CIS injection you are probably leaving performance that the carburetor can provide. CIS injections can't handle intake pulses so wide lobe centers are required. Carburetor don't haven that issue. 3.0, small port 9.5:1 with 40 Webers and a clean exhaust is a 230+ horse power engine. A CIS compatible cam will hamper that kind of output. Not knowing the M1 specs I can only guess it's performance. I would lean towards DC40 [mod "S"] based on previous experience. |
IMO, it's not the induction choice that limits the cam choice as much as the piston clearance.
I understand the argument that CIS is intolerant of intake pulses, but I have not seen that. Granted, I don't have experience with high overlap cams and CIS, but I also know that CIS was used in racing cars in the 1970's (with some modifications), and that the same SC cams were used in the Carrera engines, which had Motronic controls and could have used different cam profiles (and I know that cam choice was heavily influenced by emissions regulations too). So I'm pretty sure the full explanation is more than "CIS doesn't work with high overlap cams." I don't know the specs for the M1 cam. As far as I can tell those are not published anywhere because that's William Knight's "secret sauce." And yes, I know that cams have been around for over a hundred years and how they work is well understood. I'd like to know the specs too. But I do know this from setting up mine: They use all the available space between the valves and CIS-top pistons without running into valve interference. In my engine, (with no base gaskets) there is barely .050" clearance at the overlap checking point. THat's part of why I think that the piston clearance is what limits the use of cams with more overlap in CIS-designed engines. And that's why Ian came back with his reply that if you use JE pistons (with valve cutouts), that opens up what cams can be used. I chose to stay with CIS because my car is a street car, not a race car. I wanted the great drivability and fuel mileage that I get with my CIS and M1 setup. It has delivered that along with a significantly greater boot in the butt. I am waiting to get on a dyno to finish tuning, it, and when I do, I'll post the numbers. |
I understand the argument that CIS is intolerant of intake pulses, but I have not seen that. Granted, I don't have experience with high overlap cams and CIS, but I also know that CIS was used in racing cars in the 1970's (with some modifications), and that the same SC cams were used in the Carrera engines, which had Motronic controls and could have used different cam profiles (and I know that cam choice was heavily influenced by emissions regulations too). So I'm pretty sure the full explanation is more than "CIS doesn't work with high overlap cams." I don't know the specs for the M1 cam. As far as I can tell those are not published anywhere because that's William Knight's "secret sauce." And yes, I know that cams have been around for over a hundred years and how they work is well understood. I'd like to know the specs too. But I do know this from setting up mine: They use all the available space between the valves and Carrera and CIS-top pistons without running into valve interference. In my engine, (with no base gaskets) there is barely .050" clearance at the overlap checking point. THat's part of why I think that the piston clearance is what limits the use of cams with more overlap in CIS-designed engines. And that's why Ian came back with his reply that if you use JE pistons (with valve cutouts), that opens up what cams can be used. But, as most of you know, valve pockets have downsides too, such as reduced combustion camber efficiency and flame travel interference. Perhaps you can better satisfy those conflicts with a very different combustion chamber shape, such as what Fred Apgar was working on before his untimely departure. I have seen better head designs in Dick Elverud's shop too. But to get there, you almost have to redesign the head with a shallower chamber and probably different valve angles, such as the last developments in Harley's big twin performance engines before they went to a 4-vavle design (that was a flat top piston with a bathtub shaped chamber). Speculations for another day... I chose to stay with CIS because my car is a street car, not a race car. I wanted the great drivability and fuel mileage that I get with my CIS and M1 setup. It has delivered that along with a significantly greater boot in the butt. I am waiting to get on a dyno to finish tuning, it, and when I do, I'll post the numbers. |
Lobe centers from 110-114 degrees are basic. Overlap creates maximum cylinder filling and because carburetor and MFI can function with narrow lobe centers they can produce better relative power. Early performance Porsche cams 911S, ST, 911R, 906, RSR, all ran very tight lobe centers. 96 to 102 lobe centers. In general, low duration, low overlap is the formula for CIS and EFI. Larger overlap and longer duration for MFI and carburetors. Lift is how you develop RPM range and torque curves. When talking performance, CIS tends to go lean at consistent RPM. The metering plate, controls fuel mixture base on airflow plate lift. At lower rpm the air is relatively turbulent creating more lift. As rpm stabilizes, the air across the plate goes laminar and plate settles creating lean mixture. (fuel mileage is enhanced but the lean mixture create the tendency to detonate) Hemi heads are prone to detonation so compression threatens ignition. I created a peanut head that controlled flame fronts that allow lower octane performance. Some years later, Porsche made a similar head that helped control detonation in single plug race engines as per regulations. Supertec peanut head http://forums.pelicanparts.com/uploa...1678576507.JPG 962 IMSA head http://forums.pelicanparts.com/uploa...1678576507.jpg |
Henry, nice compact "peanut" combustion chamber. Did you also use a flat top piston? That's very similar to the "bathtub" shape (with one spark plug) Harley used before moving to 4 valves. Also similar to what Dick Elverud showed me in his shop. It seems you would not need 2 spark plugs with a compact chamber like that, as the flame should travel across the small chamber quickly with just one spark plug.
That's what Porsche should have done, but the hemispherical shape was carried forward from the 1960's. Heck, even VWs had more compact chambers. Going back to the M1, I know from looking at the fatness of the lobes that the duration is increased significantly over the stock Porsche cam and it appears they have more overlap too. It would take some measuring equipment I don't have to find the LSA. And I don't think William would be happy with me if I did that. |
Controlling the ignition as completely as possible without engine management required delaying the ignition. Dual flame fronts burn quicker requiring less ignition advance to achieve a complete burn. http://forums.pelicanparts.com/uploa...1678619869.jpg Why would the supplier of a performance part be "unhappy" if an engine builder knew the specification of a part he's installing. There are no "secrets" when it comes to building these 60 year old engines . As an engine builder, I would never use a part with a "mystery" specification. I built a race spec 356 engine for Gary Emory [Parts Obsolete] 100 years ago and he brought me a "magic" cam from a friend to use in the engine. I can't build an engine without knowing the complete formula so I called the supplier and his response was "just use it, it works great". Non-sense. Cam specs dictate cam timing based on application, compression ratio, ignition advance curve, fuel delivery and even port size and exhaust runner length. We just measured the cam and the "magic" wasn't anything special at all. |
Interesting topic. I find it a little odd though.
Without some shameless self promotion here, PD probably has one of the biggest "modern new" cam design inventories. We have designs for 911 air cooled NA engines from 2.7L all the way up to 4.1L NA, including our own version of a new "964" cam. The 964 cam seems to be some cam that everyone decided was the best solution. So we redesigned it as a A symmetrical solution. Our new designs are all A symmetrical designs, not typically sold. So what!!! Every time we sell a cam we don't worry about who may copy it. That is something we cannot control. Any engine shop that is worth its salt will have some equipment to measure the cam lobes. We use the Audie system for checking and when we get the cams cut, to ensure the lobes are cut to the design. Something that makes this a lot easier now, to copy any of our cam designs requires 4 masters to be made, 2 per lobe. Or, a cam company that uses CNC grinders but not many do. Typically we have seen cams with extremely poor copies, what we call "cut and paste" copies. For every design we can create multiple iterations by moving the LSA around. But the lobe design never changes. So, go ahead and measure that cam. Measure any one of ours. If you want to go into the cam business knock your lights out. I know how much we have invested. Too much is placed on some "special" sauce. An engine is the sum of all of its parts. |
Hi Neal
I'm not sure I understand your symmetric vs asymmetric lobe comment. Isn't it true that in order to get a symmetric valve lift curve you have to use an asymmetric cam lobe? Are you saying that a symmetric valve lift is not beneficial? Are you advocating magic ramp speed? |
On all of our testing the A symetrical designs have outperformed the older designs by a long way.
We have ported and ported and ported heads and there is only so much you can do. So, managing the air you can get through the ports. opening and closing the valves at different speeds does help. We are still testing some newer designs as opening and closing speeds are another way of changing the cam characteristics. In simple terms, the larger the port volumes the faster we need to open the valve. Pretty simple. Now add in different valve sizes and back angles and you get a whole new direction to go in. These old engine still have life in them. For years and still today, the old stuff is still sold as new. There is new technology that can be applied to these old engines. |
Port size and valve sizes are variables that offer changes in performance but there is very little "new" magic to be learned in those equations. |
Maybe you misread my post. I'll give you the benefit here.
Don't ever fall for, there is nothing new to learn. I learn new stuff everyday. I look back into my history and say to myself, if only I knew then what I now know. When people tell me there is nothing new to learn, that tells me they have a lot to learn. |
Henry, thanks for posting that graph of power vs. spark timing. I'm not sure I understand it, as I'm looking for some RPM reference relative to spark advance. Could you explain it a little please? Thanks in advance (pun intended).
For example, 4 valve head conversion would absolutely benefit the air cooled 911 [and people have tried it] but the cost to implement this innovation is prohibitive. You said you make all your cam lobe symmetrical. My question was "Why do you believe that equal intake and exhaust ramp speeds [symmetric lobes] outperform quicker intake vs exhaust speeds." The question was goofy because I used the wrong language. It should have said "Do you believe that equal opening and closing ramp speeds [symmetric lobes] outperform differing opening vs closing speeds." Do you believe that a symmetrical valve lift curve is unimportant? |
I came on here to give some opinion. I am the first to admit I'm not that smart. I do have a resume that includes some engine experience, so I guess I can at least keep up with some on here.
I never stated we made our cams symmetrical. maybe you could take the time to re read my post. As for being new to me, no but we had not done as many new A symmetrical designs for the early 911 engines. If others have then that's great. Why then do they not sell them. I offer up my opinions with the only reason but to pass along anything I can that may be of help to others. I don't come on here to get into a back and forth who is right, nor do I feel my opinion is the only one. And I do not think my stuff is the best. Its the choice of the customer to make that decision. My friend, my advice to you. Don't poke the bear to often, bears have habit of biting back. |
Why all the angst. I'm simply asking questions. I misunderstood your "self promotional" [your words] post about new innovations, I apologize. Now for the threat....."don't poke the bear" I always get a kit out of keyboard warriors. Save it for the younger guys who don't know who you are. |
First they are a relatively high quality forgings. We used them 30 years ago when Snake was still finding his way. They were horrible then. As time went on, JE got some better equipment, trial & error experience and some input from builders like myself so the pistons started to work better in Nikasil cylinders. Next there is rapid development and production time. If you have a special design in mind [dome shape, ring package, forging configuration] after markets pistons offer that. Third there is a reasonable price. Building these old motors is a crazy expensive proposition. If you can find a quality part that offers the configuration you want at a more reasonable price, why not use it. Now all that said, we don't use JE pistons as much as we used to. We're finding working with CP more compatible for our needs. We like their forgings, quick development times, small custom run requirements and ease of communication. They are a little more expensive but for the reasons I listed, they are the best option in most cases. We're building a 906 that needs pistons and the off the shelf piston that Mahle offers don't fix our requirements. |
Are you asking for the advance curve for a specific engine? If that is your question, I need a lot more information. Building an engine is a symbiotic adventure. All parts have to work together. That is why "mystery" cam specs strain credulity. How can you formulate a anything without knowing the ingredients. Even when Emeril "bams" his gumbo the ingredients are listed on the label. If your question is more generic, setting your advance with respect to rpm @ maximum torque is critical. Dyno numbers become important at that point. "The plan is to light the charge in the cylinder with enough lead time (advance) to create maximum cylinder pressure at the ideal point after top dead center (ATDC) to push the piston down, exerting leverage on the crank. It's generally acknowledged that peak cylinder pressure needs to occur at roughly 15 to 18 degrees ATDC to maximize leverage on the crankshaft. If the spark timing is too early, the cylinder may experience detonation and potentially cause damage. Too late and un-burned fuel is flowing into the exhaust." |
Great simple explanation
Henry, thanks for the continuing conversation. First question: Did you generate this chart based on your own data, or is it from an SAE paper or similar source?
The title: "Power v/s spark timing (at 1/2 throttle position)" raises several questions: Is throttle position measured as the throttle plate halfway open, that is, about 45 degrees to airflow? Or is it 1/2 MAP (about 7.3 PSIA)? I ask because 1/2 throttle plate open is pretty close to full MAP, especially at low RPM. So that influences how I interpret the rest of the chart. And, what does "v/s" mean? "Versus" or something else. I think you mean "versus, " abbreviated "vs." Next, the chart labels the axes "power" and "spark timing" and plots two curves, one for single plug, and another for dual plugs from 25 to 40 degrees of advance. I interpret a couple things from the chart. First, that a dual plug setup makes more power at lower advance than a single plug. Second, that as advance increases, the power difference between them converges. Now, at 40 degrees, I expect that to be the sum of the advance required for higher RPM and the advance for high manifold vacuum (low MAP), which generally indicates low engine load. But if the engine is operating at low load in that part of the chart, the power should have reduced, rather than turned up at higher advance or right side of the chart. So this doesn't make sense to me. How do you interpret it, and how do you use it to inform your engine building? |
The title: "Power v/s spark timing (at 1/2 throttle position)" raises several questions: Is throttle position measured as the throttle plate halfway open, that is, about 45 degrees to airflow? Or is it 1/2 MAP (about 7.3 PSIA)? I ask because 1/2 throttle plate open is pretty close to full MAP, especially at low RPM. So that influences how I interpret the rest of the chart. And, what does "v/s" mean? "Versus" or something else. I think you mean "versus, " abbreviated "vs." Next, the chart labels the axes "power" and "spark timing" and plots two curves, one for single plug, and another for dual plugs from 25 to 40 degrees of advance. I interpret a couple things from the chart. First, that a dual plug setup makes more power at lower advance than a single plug. Second, that as advice increases, the power difference between them converges. Now, at 40 degrees, I expect that to be the sum of the advance required for higher RPM and the advance for high manifold vacuum (low MAP), which generally indicates low engine load. But if the engine is operating at low load in the part of the chart, the power should have reduced, rather than turned up, at higher advance. This doesn't make sense to me. How do you interpret it, and how do you use it to inform your engine building? |
Talked to Henry this morning pleasant conversation very knowledgeable. He suggested Mod S cams or DC 30’s.
Engine development is a art unto itself. Neil might be the place to go for the theoretical. |
So what’s the difference between a regular cam and a modern cam?
Isn’t a cam all about making the most out of a given engine . Is the modern cam going to give more power or what am I missing ? |
This formula was an attempt to reduce valve train parasitic loss do to high friction. As a result, early 911 cams seem to give up low end torque. What might be considered a modern 911 cam has a formula more in line with most conventional cam designs. Higher lift, shorter duration. This tends to produce better low end numbers but with most examples, you need higher valve spring rates. Now we start revisiting the higher friction issues. Friction means heat, wear and changing spring pressures means changing spring harmonics. It's all a dance to produce a desired result with the least compromise. This old 911 design has a compromise at every turn and when people like Neal look to design things like "new" cams, reducing these compromises is the goal. BTW: making the most power is a racer's mentality. Cams design is really about finding the compromise that makes for the best driving experience. An 8000 rpm 911 is a cool short term blast but a miserable thing to drive on an extended highway trip. Small displacement/high RPM cars are frantic to drive. Shifting mistakes [$$$$] become the norm. To best thing about modern cars is crazy performance without hysterics. |
Most of the cam profiles sold in the 911 world are all based on what was deigned back in the 50's and 60's by Harvey Crane. Porsche did not sell upgraded cam designs so many of the profiles offered for other engines in the aftermarket, we looked at copied and used in the 911 world. Copies of copies etc., etc, have been sold for years to the 911 world. For many that is ok and everything they want. Many do not want to go out on a limb and try something new. We are all like that in our lives. I have no problems with that. But our DNA is to create and design new parts for any engine we get involved in. We did this years ago for the air cooled world. Then the water engines came along and we focused on them. Cranks, Rods, Pistons, Cams etc, including the solution for the 991.1 finger follower issue. Then a few years ago we were asked by several companies around the world to look at the 911 air cooled engine again. We looked at what was offered and saw areas we could improve. We redesigned our original Head studs, case through bolts, and looked at the camshaft selection that is currently offered. There was an opportunity to offer profiles that help control the valve motions a lot better. We have learned a lot about valve motions since the 60's. Much of it has never been applied to the 911 world. Materials, coatings, Springs and weight have all come along way. So we decided if we were going to get back into the 911 camshaft aftermarket we would offer valve motions that were current. All of our new designs are Asymmetrical where needed and some are still symmetrical but these designs are improved versions of our older profiles. Demand on them would not warrant spending the time and investment on Asymmetrical valve motions. The factory 964 is a classic example of how far behind 911 valve motions are. The 964 is a profile out since the mid 80's and still appears to be better than a lot of what is still offered today. This new stuff is not for all. Some are happy with what they have and what is offered. What is the real shame, we are not the "cam business". Those that are should be the ones leading the way. |
I understand that My Pillow comes in a 2.0 model. Innovation is good, sometimes "new" is just a marketing ploy.
Neil is trying and should be commended but sometimes Bronzonium is just Bronze. |
And if you are not the lead dog the view never changes.
Like the lip stick on a pig theory. But I will keep trying. |
| All times are GMT -8. The time now is 03:11 AM. |
