-   -   Where can I find a 8 port vacuum manifold block for my 930 ITB engine setup (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1136742-where-can-i-find-8-port-vacuum-manifold-block-my-930-itb-engine-setup.html)
vvmhk 03-18-2023 05:07 PM
I am currently looking for an 8 to 10-port vacuum manifold block for my rebuilt 930 engine with ITB to connect with my brake booster, etc. However, I mostly am able to find 6-port configurations online. Is there anywhere that sells vacuum blocks in 8 to 10 port that fit my purposes? Many thanks in advance for the assistances.http://forums.pelicanparts.com/uploa...1679184401.jpg
stownsen914 03-20-2023 01:28 PM
Just googled and found some options at Summit Racing
vvmhk 03-23-2023 08:18 PM
Thanks Stownsen914,
I will look into it.
michaelmount123 03-23-2023 08:49 PM
McMaster-Carr is always your friend:
https://www.mcmaster.com/products/vacuum-manifolds/right-angle-flow-rectangular-manifolds-7/
Louis69 03-28-2023 04:35 AM
You may want to consider contacting a specialized automotive parts supplier or a manufacturer that specializes in vacuum manifold blocks. They may be able to custom-make a manifold block with the number of ports and specifications you need to fit your specific engine and configuration. Alternatively, you can also check with performance or racing shops that specialize in ITB setups for custom solutions.
HISD Connect Parent Portal
phunt 03-28-2023 09:46 AM
Clewitt has them already made for boosters
winders 03-28-2023 11:50 AM
If you are getting this manifold in the hopes of tuning using MAP instead of Alpha-N, you may want to go with a bigger manifold that will dampen the pulses and provide a more accurate MAP. Check with your tuner...
Jeff Alton 03-29-2023 08:48 PM
^^^^^ Yes, we have used many different sizes, most we built. The smallest was slightly bigger than these. But in all cases we were able to get a stable signal.
We will be making our own for the 2 ITB motors on the go currently and will move up in volume to eliminate any risk.
Cheers
