-   -   ITB Conversion Kit? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1137271-itb-conversion-kit.html)
jac1976 03-31-2023 09:39 AM
Hard to argue with the “look” of trumpets, but I’ll be dammed if your motor doesn’t look great.
thetorch 03-31-2023 09:52 AM
Speaking of looks Jac, still waiting to see those 7" aluminum steelies I sent you last year on your ride. :)
Jeff Alton 04-01-2023 09:18 PM
Originally Posted by jpnovak (Post 11960842)
I have installed and worked on a bunch of different ITB setups. here are some of my thoughts.
PMO
-Easy to install and balance
-Linkage arms often need considerable adjustment to have same arc travel balance on each side.
-Good airflow
-Can use KN watershield air filters
-Can buy as ITB only if you are converting from Webers. Uses same manifolds and linkage.
Borla (formerly TWM)
-Good airflow
Triumph Triple
-Budget adaptation
-Limited injector selection
-linkage is usually terrible.
Jenvey
-work well
-IMO Linkage is not easy to setup. But works well once going.
-Look very much pieced together.
-Challenge finding good filters for stacks.
RHD
-Linkage works well.
-Easy to setup and balance.
I have not tried AT or JSR but they both look very interesting to me.
On a street car you will not noticed the difference between most of the readily available ITB setups. The end result will be your ECU choice and more specifically the tuner that completes the installation, setup and tuning process. This is where you get excellent or mediocre results.
for a street car I would make sure you have good filtration. There are many examples of cars with open stacks. This is just asking for water or dirt ingress leading to damage. I am not a fan of the snap on "mesh filters". to me they rob too much power.
Jamie, I find it odd that you had trouble sorting filter options for Jenvey and RHD, as they offer them.... :)
The Jenvey's do require a few extra minutes getting them dialed in, but then are very stable and repeatable. To date, they have been our "go to".
The PMO, not sure if you can even get them even after the EMPI aquisitsion, used all Weber compatible parts. The manifold was the biggest detractor...
Cheers
Mongo84 04-04-2023 07:40 AM
Originally Posted by OSC911 (Post 11959542)
I went with the Rasant kit - Motec M84, PMO and milspec harness. Really nice gear but the lead time was quite long and the tech support was pretty average.
If I had my time again, and knowing that Clewett are now using the Haltec ECU range, I would definitely go with them, just for the support they are known for. I don’t have any experience with his new ITB, but they look great.
Did you recently pick this up and if so where were you able to get it from?
Thank you
Sent from my Pixel 6a using Tapatalk
winders 04-04-2023 10:47 AM
Here are my "drive by wire" AT Power ITBs.....
http://forums.pelicanparts.com/uploa...1680630368.jpg
PeteKz 04-04-2023 11:07 AM
Looks great!
al lkosmal 04-07-2023 10:26 AM
RHD with rainhats
RHD with rainhats......
http://forums.pelicanparts.com/uploa...1680888319.jpg
regards,
al
al lkosmal 04-09-2023 10:42 AM
More RHD w/rainhats/filters.....
<iframe width="839" height="629" src="https://www.youtube.com/embed/6NcE3cPvosQ" title="3.2SS...ready to ship" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
regards,
al
mikedsilva 04-10-2023 03:21 AM
regards,
al
That runs very smooth.. which cam is it running?
al lkosmal 04-10-2023 09:40 AM
Mike,
That's a 3.2SS with Webcam Mod-S cams.
regards,
al
H-viken 04-11-2023 04:28 AM
Originally Posted by Henry Schmidt (Post 11958142)
We make our own but they are still in testing. Not ready for prime time.
New twist on an MFI design.
The manifold were cast using old Mahle pistons.
http://forums.pelicanparts.com/uploa...1680016296.JPG
Hi Henry
What’s the article number of that ITG filter? Are you using the standard baseplate or have you cut it yourself?
Curious to know the measurements
Cheers!
Johan
Raceboy 04-11-2023 10:07 PM
Good overview of available kits from Jeff.
I made my own conversion using GSXR throttles, custom manifolds and linkage. Used Pipercross filters and CNC cut custom filter backplates. Definitely not too easy but it iw working great.
Regarding idle air, with electronic throttle setup there is no need for such thing. DBW compensates for cold starts, any higher load at idle (for example high beams etc), always perfect idle like normal car.
Plus one can have custom pedal vs throttle opening profiles, helps traffic driving tremendously.
I used BMW E46 M3 (S54B32) throttle actuator and BMW E46 throttle pedal. VEMS ECU controls everything.
http://forums.pelicanparts.com/uploa...1681276031.jpg
winders 04-11-2023 10:21 PM
These are some of the things I am really looking forward to with my new DBW setupfor my race car. No more having to sit in the car to keep it running until it warms up. Just start the engine and forget about it. I'll set idle speed based on head temperature via the MoTec M150.
Being able to control the throttle using a progressive curve of my choosing is going to be awesome!
twickes 04-12-2023 05:17 AM
I ran Andrews kit for a year and we had a major issue with the AEM brain and his crank sensor. I then swapped (my cost) the AEM for a Motec which helped but still wasn't perfect. I would agree, the service was not great, and then out of nowhere Andrew just closed shop.
Buy based on service, these are not plug and play systems.
Matt Romanowski 05-02-2023 06:17 PM
Mark at Exotech just did RHD throttle bodies, COP, and a MaxxECU on my 3 liter for my 914. It's wild to just reach in and hit the start button. The car starts immediately and just idles. He has to finish tuning it, but it was really fun at Summit Point this weekend!
http://forums.pelicanparts.com/uploa...1683076531.jpg
The Maxx is really powerful. I have future plans for DBW, but that is a ways out.
JmuRiz 05-03-2023 06:52 AM
Nice!
r_towle 05-03-2023 12:42 PM
Curious, what are the pro/con of a centralized TB and plenum versus ITBs?
Rich
Gonbad 05-03-2023 01:11 PM
Rich
For one and it’s a major one - the 964 setup is easier to tune as there are less variables to deal with.
Matt Romanowski 05-03-2023 01:13 PM
I won't claim to be an expert, but Mark at Exotech had my car start, idle, and drive very quickly without trouble. The on track tuning was close and he is getting that dialed in really quick. As a customer, I don't think the ITB made it any harder.
targa72e 05-05-2023 12:26 PM
When using a common plenum with a single throttle body you are limited to cams with small overlap. When there is large cam overlap and a common plenum the air/fuel mixture will be blown back into the intake at idle and low speeds making for a poor running car. Because ITB's and carbs have a throttle plate over each cylinder that is closed at idle they keep the aif/fuel mixture from being blown back up the intake. This allows you to have a more aggressive cams and still have a car that will idle and run well at low rpms. So cam choice can dictate what type of intake you use.
john
