Who makes these twin plug wire sets?
Does anyone know who makes these plug wire sets for twin plug? They are labeled already for upper and lower banks and cylinder. I like the looks of them too.
Not the coil leads. The plug wires. Thanks ! http://forums.pelicanparts.com/uploa...1681663241.jpg |
those look like Clewett Engineering to me.
Thanks Coblue ! Will reach out to Clewett.
Building a twin plug 3.2 and down to sourcing the last few items. |
My twin-plug doesn't have a distributor, it uses crankfire ignition. You might ask the ppl at Patrick MotorSports if they know of a se of twinplug plug wires for a distributor., if Clewett can't help.
Is the distributor hold down washer underneath the distributor? It needs to be under the hold down nut.
Great eye- looks like it is under the distributor.
Might be Clewett because Kingsborne make Clewett plug wires. |
Thanks everyone !!
Jim is saying the manufacturer in Kingsborne [I agree] and the retailer might be Clewett. Kingsborne make plug wire sets for a many different retailers to sell under their own name. Richard uses a "special" plug connector which we can't see in the picture so "might be Clewett" is completely accurate. http://forums.pelicanparts.com/uploa...1682266530.jpg |
I had to call Clewett and ask for a longer coil wire (my coil is on the fire wall). Talked directly to Richard, not only did he have one in stock sent it out overnight at no charge. Just great service.
| All times are GMT -8. The time now is 09:29 AM. |
