Rasant Cam/Crank Sensor Assembly
I have a Rasant Products Cam/Crank Sensor with about 5k miles on it. It has developed a ticking noise that I am having trouble diagnosing. I have taken the cap off a couple of times now only to find a bearing surrounded plane shaft that has a disk bolted to the top with a magnet on it (no place to tick/rattle). At the other end is the brass gear. The only thing that comes to mind is that the bearings could be loose/failing causing this ticking noise. Has anyone else experienced this problem? Any suggestions?
'81 911 SC
'03 BMW M3 (Sold)
'64 VW Beetle, 2332, 48 IDA (Sold)
Instagram: @j_smallwood
Old 05-22-2023, 09:17 AM
