Twin plug lower spark plug connectors?
Is there a good source for longer Beru (or other) spark plug connectors that will fit the lower valve covers? The top ones are a bit short to be used at the bottom.
I know Clewett and stock 964 wires would work, but I'm looking for a removable connector so I can make my own wires. What do you all use for the lower spark plugs? |
Stock ones work fine. If u have turbo lower covers a bunch of the ribs need machining. http://forums.pelicanparts.com/uploa...1684969440.jpg
Stock connectors with ribs notched.
http://forums.pelicanparts.com/uploa...1684970312.jpg |
Thanks Rick, the second picture with the notched ribs is helpful, I'll do the same.
Check out the Clewett plug wires/connectors.
| All times are GMT -8. The time now is 12:23 PM. |
