Tips for replacing ex manifold studs
Anyone have any good tips for removing the exhaust manifold studs from the heads? I was going to just grip them with vise grips and twist them out. Should I heat the head with a torch first?
Thanks. Roger |
A much discussed topic here.
Use the search button. Start here: http://forums.pelicanparts.com/showthread.php?s=&threadid=106558&highlight=exhaus t+AND+studs Cheers, Jim |
why, is the first question. best to let sleeping dogs lie, unless there's a good reason. they don't come out easy, and generally need to be drilled. that requires a jig, so the drill is dead center and doesn't go off into the aluminum head and create more problems.
As usually, I agree with JW...
Don't pull them out unless they are super-rusted. -Wayne |
| All times are GMT -8. The time now is 12:46 PM. |
