So, a bit of input from a guy who designs engines at GM for a living...
As Dannobee states, modern engines as a general rule just don't leak. While it is obvious that flanges have to be really clean when the sealant is applied, the real key is in the design of the joint. A 911 case has 20mm of sealing land. The problem is that with all those heat cycles, the joint moves. A micron or two or less of sealant doesn't offer enough compliance to account for that movement, so eventually the joint leaks. At GM we do the job with less than 9mm. The difference is that one of the two flanges has a 1mm step in it. The RTV fills in that gap, and creates a 1mm thick flexible seal. Bingo. No leaks. I'm frankly surprised that none of you professional builders, or shops like Ollies, haven't adopted the design. I think there's more than enough stock on a 911 case flange to accept it. A simple cutter path, and you'd have a much more robust seal. I would unequivocally do it to my own case that I'm building, but hiring a shop to program the cutter path, fixture the part, etc. for a one-off is a little cost prohibitive for my wallet... |
The better mouse trap.....
Properly clean, inspect and gently massage the sealing surfaces [Scotch Brite by hand] and a non-silicone [snakes in the drain] sealant that is flexible and you're good to go. We have engines that have clocked in excess of 250K miles without case half leakage. Our sealant of choice is ThreeBond 1184 for case halves. Is that a guarantee that this method will work? we give a 2 year unlimited mile warranty against leaking, so I would say we have confidence in this method. Even on twisted old mag case engines. |
Henry, as always, thanks for sharing your hard-earned professional advice.
Detroit: Thanks for that insight too. I have noticed that the mating parts in a number of applications don't line up exactly. I always thought that was just manufacturing differences, but now I understand why and that it's deliberate. I've done something like that by using a hand file to chamfer the inner edges of parts that have to contain fluids, to create a little V between the mating surfaces to hold squeezed-out sealant. Not even a millimeter. It seems to work. I did not do this on my last engine build, but I will next time! Since the bottom of the case springs the most leaks, maybe the flanges from the front oil seal to the rear oil seal are all that's needed. |
I've put together cases for 40+ years and have gone thru a number of Permatex and Loctite products. Here is a new one not mentioned in any posts above which I might try on the engine I'm building now ... Gasgacinch 440C. The product has been around for decades, but I've never heard of it being used to seal cases. Has anyone else tried it?
I’m planning to fix my leaking case seam using the vacuum infusion process described in post #2.
Is it viable to do this with the engine in situ? I would expect the vacuum to pull oil from the oil tank through the pump an in to the case. Or will it easily seal the 10 psi vacuum? Has anyone done this ? Thanks |
Our shop plans to do this procedure with the engine in the car. Shop will add die to the oil and look for the leak with a black light. All oil is removed from case and tank - seam needs to be dry and clean. Our shop plans to do with 10 psi vacuum. As reported in #2 this has been done several times. Our car goes into the shop on Monday 7-10-23 . . . I'll report back on the results. Regards, Roy T |
Your feedback on the process once carried out will be highly appreciated. Regards Hans |
leak fix
Regards, Roy T |
Oil leak solved!
The results are in =
NOT a case seam leak! NOT a case seam leak! OOOPS . . . yes, a very very small case leak just below the major leak in the intermediate shaft bearing O ring leak :eek: see my post on 7-21-2023. . . The shop will now do the vacuum procedure . . . The Intermediate shaft bearing O Ring was leaking - why (?) because there was a lot of machine work done on the case including a line bore and shaving of the case - causing the IS Oring hole to be oval rather than a perfect circle. The Tech found it right away and removed the cover and redid the O Ring with more silicon - leak stopped - ran the engine up to temp (20 minutes) and let set to see if the leak has stopped - the shop will watch it for a few days to make sure it is fixed. The case half seal does not leak it was just the place the oil ran to by gravity . . . ha ha . . .The shop Tech Roland explained all of this very thoroughly to me - Thanks to Don Jackson's in Phoenix! Photos from another post in 2022 (thanks to Uwon) that show the cover and O Ring - a different engine but the same 2 bolt cover (should be 3 like the older engines (?)) http://forums.pelicanparts.com/uploa...1689940318.jpg http://forums.pelicanparts.com/uploa...1689940318.jpg From Bruce on Uwon's post : "Cover for the intermediate shaft There is a green rubber seal that goes on it to replace original red Lube it and install without pinching Bruce" https://forums.pelicanparts.com/911-engine-rebuilding-forum/1114558-seniors-moment-leaking-cover.html Thanks to michaelmount123, Bill Verburg, Neil Harvey, John Walker, Henry Schmidt, dannobee, detroit and others for contributing to my request!! Regards, Roy T PS: The shop did this repair with the engine in the car - just had to remove some tin and the saddle carrier (?) to get to the cover plate. |
I've seen this approach touted over the years and never really understood the recovery process. |
Thanks again for all of your help! I'll update when we have some more results . . . Regards, RoyT |
I found a similar leak in mine at the same location oddly enough. I plan to try the vacuum procedure and hope it will seal. Will be interested in your results on this -
Of course the big leak was in the intermediate shaft O ring - which they fixed. Wish you the best on your project (leak) Regards, Roy T |
Sorry to hear you had problems with this. I guess I got lucky, in that my leak turned out to be from a torn cam gasket. Once I go that fixed, no more leak, at least not there. I have a small one now at the rear, but might be coming off the top of the motor. Almost too small to worry about at the moment. So glad I didn't have to do the vacuum procedure though.
I was suffering from insomnia one night, so I counted all the places oil can leak out of an air cooled 911 engine. I got to almost 100 before I fell asleep. I’m sure I missed a few.
10 psi vacuum? Maybe 10 inches of vacuum?
| All times are GMT -8. The time now is 03:26 AM. |
