-   -   Who's boring plastic MFI stacks? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1141214-whos-boring-plastic-mfi-stacks.html)
Tyson Schmidt 06-06-2023 02:26 PM
I need to get a set of plastic 911T MFI stacks bored out to S/RS size.
I asked Henry at Supertec a while ago and apparently Aaron stopped doing it, and I don't know where else to turn.
Anyone else doing this?
john walker's workshop 06-07-2023 07:57 AM
Eurometrix maybe. Ask Mark Jung, 356rs.
BURN-BROS 06-07-2023 07:18 PM
Big changes for me , but I will resume this work this year. I’ll send out updates when I’m set up.
BURN-BROS 06-07-2023 07:57 PM
I’ll be moving into Retro-Sport’s 15,000 Sq feet of Porsche goodness located in the San Francisco Bay Area! Lots of work ahead to move in and get up and running.http://forums.pelicanparts.com/uploa...1686193294.jpg
Henry Schmidt 06-08-2023 05:49 AM
Great to hear.....it seems like I may have as many as ten sets waiting for the rocket man to return to earth. The Porsche world that is.....
Tyson Schmidt 06-08-2023 04:06 PM
Great to hear! Now take my money.
Rosco_NZ 06-09-2023 04:41 PM
May be able to help ..
Henry Schmidt 06-11-2023 09:35 AM
As much as the "Return of Aaron" is exciting, we're designing some tooling to make boring these stacks possible with our limited equipment.
We have a crazy inventory of MFI stacks, butterflies and pumps that need to find some updates to make them more adaptable to popular builds.
Matt Monson 06-11-2023 02:00 PM
I’ve got a set that were done by Mike Bruns that I’ve been thinking of selling. We should talk.
r lane 06-20-2023 04:02 PM
If there is going to be a considerable demand and sounds like Henry may provide that, a CNC program would I suppose be justified. If you are just doing one, the only piece of equipment needed is a mill. I realize everyone doesn't have one, But in the various gear head communities, bet someone has one. I bored out a set of 2.2 mag stacks to 47-40 for a 3.0 track motor. My method was crude and primitive, counter to standard machining principals, time consuming, but I was amazed at the finished product. A very rigid fixture for the stack assembly, a 18'' sturdy boring bar, a fixture for a 1'' spherical bearing to support the bottom of the bar while the top is held in the spindle. All of these are made by you. The bit was 1'' with a taper to match the angle of the stack bore. Dropped it in 1'' at a time and made lateral adjustments to the bit for each cut. Finsished up with 3 tapered hones with 3 different grit surfaces. Very time consuming but the plastic stacks should be easier. Bob
gereed75 07-19-2023 09:12 PM
I am pretty sure that Karl at Thoroughbred Motorsports in Corty PA has tooling to do this.
PeteKz 07-20-2023 01:02 PM
Stacks would also be a good candidate for 3D printing.
