Crankshaft ID for Holder - Home Made
Can anyone tell me the interior diameter of the crankshaft hole found on the flywheel end? Ours is from 914-6, but I think part number 901-102-011-00 is 1965-71 911 applicable at least.
Opposite side presumably held by pulley M12 hexagon-head bolt.
I don't have access to my crank right now, and am thinking of making a home made vertical crankshaft holder. Similar to what Mike's Restorations has done.
I am aware you can get a very nice tool from Stomski, but I will probably only use this once and can't justify buying one.
Old 12-16-2023, 09:41 AM
This design also works well. You could make one easily.
or just buy one:
https://goodson.com/products/professional-measuring-and-inspection-stand
Old 12-18-2023, 04:57 PM
Tags
crankshaft , engine
