1974 2.7 Engine - #8 Nose bearing
I just finished taking apart an engine I bought years ago. On each side of the case, there are two groves that line up with grooves on the old #8 bearing with brass dowel/pin, which I'm sure is not how it left the factory. Before I start sending parts to the machine shop, I'm wondering if the case can be repaired. I'm sure that assembling as is, it will leak badly.
Old 07-09-2023, 05:18 PM
Constitutional Liberal
Turbo_pro's Avatar
Looks intentional but but should be repairable. Just weld it and aline bore the #8 when you aline bore the case.
Aline bore number 8 bearings are readily available.
*Although certainly not the best option, properly applied epoxy might also do the trick.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 07-09-2023, 07:00 PM
My engine case had corrosion on the #8 bearing saddle. Ollie’s machined it a little larger to allow for a 3.0 930 nose bearing.
Old 07-09-2023, 10:04 PM
Look at all that set up Loctite 574. It didn't squeeze out before setting up. Probably caused a #8 leak all by itself. That's why I don't use it.
206 637 4071
Old 07-10-2023, 07:04 PM
If you use Yamabond or Titebond at the grooves and the Wrightwood Racing viton o-ring there will be no leaks , but the case is probably warped and needs machining
anyway .
Old 07-10-2023, 07:48 PM
