1970 911t 2.2
i am rebuilding an engine i recently purchased for my 1970 911T , 2.2 .
i had the casing line bored at Competition Engineering Inc in California which will require the installation of 1.0 mm shim to compensate for the casing surface machining.
Also I had the Cylinder heads restored and machined to the tune of another 1.0 mm shim requirement.
both machine shops indicated that it is not for certain that I need the relevant 1.0mm to compensate for their work but I might need to do few trial and error measurements with Play doh to figure out the exact total size of the required shims.
I have purchased 0.25mm, 0.50mm and 1.0mm shims.
can anyone tell me how many shims is acceptable or allowed? as i may need 1.75mm total. (it means one of each of the shims I bought. worst case scenario) Please help. Thanks
Old 07-22-2023, 05:24 PM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Typically one shim is installed but 2 can be stacked. Not sure if anyone has ever tried 3. If 1.75mm was required to maintain deck height, I’d get some custom made.
Old 07-27-2023, 10:41 AM
Kamalea, I have the same issue with my '71T. My calculations indicate I need 1.5mm in shims. Do you mind sharing where you bought your shims?
Thanks.
dho
Old 07-27-2023, 04:21 PM
Under the radar
Trackrash's Avatar
Gordon
'71 911 Coupe 3,0L outlawed
Old 07-27-2023, 04:45 PM
