-   -   #8 nosecone bearing sources - matters? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1143605-8-nosecone-bearing-sources-matters.html)
stownsen914 07-22-2023 05:17 PM
After cleaning up the nosecone bearing for my rebuild, I'm noticing a few nicks and scratches on the ID that I can catch a nail on. Although it measures within spec with a bore gauge, probably safer to replace. Do we need to be careful about the source of the #8 bearing like we do for other bearings, i.e. quality issues with Glyco bearings from certain sources?
stownsen914 07-25-2023 04:54 AM
I see Rausch & Spiegel sells a #8 bearing. Is that a quality part?
mikedsilva 07-25-2023 06:20 AM
I've used those and the cheaper OEM ones and never had an issue.
Billthebuilder 07-26-2023 01:50 PM
Probably the nicest part on my engine
