Cam clearance specs
Would anyone have any cam shaft clearance specs for a 49 mm cam towers? I’m working on a set of 1977 3.0 cam towers with Web Cams 20/21 cams. Thanks
Just to clarify, I’m talking about the clearance between the cam journals and the bores.
0.025mm - 0.066mm. Service limit 0.010mm.
0.0010" - 0.0026". Service limit 0.004" |
Thank you so very much!!
