Weight of 914 Six Engine and Transaxle
I am in the process of removing the 2.7 liter flat engine and transaxle from my 914 six and would like to know the approximate weight of the engine and transaxle so that I can choose which floor jack to use.
Lauran
Old 08-01-2023, 08:35 AM
Under 500kg. Never seen a floor jack that small.
Sent from my Pixel 7 using Tapatalk
Old 08-01-2023, 09:06 AM
buster73's Avatar
Should be in the range of 180 to 200 kg for the engine and 50 to 60 kg for the transaxle (901 or 915 Mag or AL) which adds up to 230 to 260 kg (500 to 575 lbs).
Regards,
Guenter
73.5 911T, mod
Old 08-01-2023, 10:23 AM
The 9 Store
About 420lb for a stock engine with exhaust. 72 lbs for the trans.
All used parts sold as is.
Old 08-01-2023, 10:59 AM
Get a Harbor Freight 1000lb lift table. Cheap and would be great for a 914 eng/trans R&R.
206 637 4071
Old 08-01-2023, 12:15 PM
Location: behind the redwood curtain, (humboldt county) california
+! great tool
This is a GREAT TOOL.
It makes the engine R&R a safe one man job, (still is nice to have help).
It can be a very mobile - multi height work table. Less bending over and getting up and down.
Very helpfull loading and unloading heavy stuff from back of truck, like appliances, wood stoves.
chris
Old 08-02-2023, 07:30 AM
The 9 Store
We have 4 of them at my shop. They get used everyday.
Old 08-02-2023, 08:32 AM
Racer
winders's Avatar
I have two of them and they are invaluable when removing and working on my race car's engine and gearbox.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 08-02-2023, 08:56 AM
About the only thing good at HF.
206 637 4071
Old 08-02-2023, 01:27 PM
PCA Member since 1988
Those engine weights are high. I weighed my 3.2 as I put it together with CIS FI. Ready to install, it's about 360lbs. The magnesium engines are supposed to be about 20lbs less.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 08-02-2023, 11:05 PM
With the lift table, just make sure you know the minimum height they can do depending on your lift or jack setup. If you have a lift that goes higher than 3 feet (+/-?) the tables should work. Less than that I would really check all your measurements so you are sure you can roll it out from under the car when you put it on the table.
Alternatively, the ATV jacks can have very low min heights (3-4 inches) so they work with regular jackstands or a quickjack where you can only get the body about 24 inches off the ground.
Old 08-03-2023, 07:54 AM
Racer
winders's Avatar
A mag case 915 with Guard LSD weighs in at 109 lbs.....
Scott Winders
PCA GT3 #3
Old 08-03-2023, 08:59 AM
