I just finished the con-rod checks. Still round at 50ft-lbs, and at .010” stretch. |
The engine has 149k pluss (???) broken odometer. Cam (964 Grind), follows, heads, oil pump, head studs, piston and cylinders are being addressed are all being addressed. |
Keen to compare findings... As for re-using old bearings, I cannot bring myself to do that. Maybe I'm wasting money? |
I haven't measured the tunnels on my small handful of Porsche builds. If there isn't any apparent wear in the bearing saddles (like embedding of the marks on the back of the bearing shells into the saddles), I don't see how they could be much different than when Porsche assembled them 40 years ago. Maybe they weren't in spec then?
On my last build (my current 3.2 into my 1973T), I used Plastigage. The case was a 1980RoW 3.0. I bought the crank and rods (a turbo 74.4) from Dick Elverud, and he had checked and polished it, so I knew it was straight. I installed the new main bearings, laid the crank into the bottom half, installed the top half, and torqued the case bolts to spec. After diassembling, the Plastigage showed right at .002" on all the mains. Close enough for me. That's the measurement you're really after anyway. As for reusing bearings, I still like to use new bearings, even though I can't see that there is a benefit IF the old ones are in good condition and the plastigage measures within tolerance. Yeah, old habits, abundance of caution, etc. But with some poor Glyco bearings in circulation, Not to mention rising prices of high quality new ones, I'm somewhat more inclined to keep using original good ones now. Important factor: I'm not a pro builder, having to warrant my engines to customers. I'm a heavy DIYer, so I'm willing to save money and time on things that I don't think make much difference. I didn't rebuild or buy new rockers and shafts either. They looked good enough to me. If I have to replace them at some point, I'm willing to do that. If I was giving a warranty, I'd rebuild or replace them too and just add it into the price to the customer. |
| All times are GMT -8. The time now is 01:08 PM. |
