Intermediate Shaft Gear Sets 0 & 1
Is the application difference between 0 and 1 to compensate for Crank Centerline to IMS Centerline differences in the case during initial build?
Set the gear backlash with the different sized gears. There's a chart in the workshop manual.
There is a size stamped on the pulley side of the cas to the left to match the IS.
Bruce |
Anyone agree/confirm? |
Yes, like many things on 911 engines the parts were matched after machining to get tighter tolerances. Ultimately you are looking for a certain amount of backlash. Thread below has charts that show the mix of 0 & 1 cases along with Intermediate shaft gears and acceptable backlash and machining differences.
Intermediate shaft assembly question? john |
Thanks, i’ll be checking that during my assembly.
Rosco_NZ
Only as it left the factory. If the case &/or int shaft has been align bored, the numbers may not apply. Measure gear backlash is the only way to be certain.
