-   -   Help with 996 bearing carrier model (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1145876-help-996-bearing-carrier-model.html)
mmasse 09-06-2023 10:46 AM
Hi
I am rebuilding the engine for my race car BOXSTER 1997 SPB
I ordered the crankshaft carrier bearings twice but I got ones that come with a notch ( 996.101.131.64) pic below
The problem is that my crankshaft carrier does not have grooves for the bearings.
Anyone knows what would be the right part number for these bearings without the notch?
Any help is greatly appreciated
Thank youhttp://forums.pelicanparts.com/uploa...1694022298.jpghttp://forums.pelicanparts.com/uploa...1694022347.jpg
mmasse 09-06-2023 04:08 PM
Anyone please!!
befoki 09-10-2023 10:43 AM
Also need 1
mmasse 09-10-2023 11:16 AM
I ended up taking the carrier to machine some grooves. Nobody seems to know anything about a carrier without grooves. Rare specimens 🤣
Jeff Alton 09-11-2023 06:26 PM
Well, to be frank, the 2.5 motors have little value. So, most are not willing to invest in rebuilding one as the cost far exceeds the value- for a shop to build it. Make sense?
I have a 2.5 block I had sleeved to use in a future bigger bore build. Have had it for 7 years.... :)
At any rate, sounds like you have solved your bearing issue.
Cheers
