Banned
Experimental coke oven
The coke oven carbonization chamber adopts a building block design, which is convenient for masonry and maintenance. The furnace walls are made of thin-walled silicon carbide bricks, which shortens the oven time and the coking cycle. The 40kg test coke oven adopts programmed temperature control heating and has a good working interface. vacuum-brazing-repair-method-for-cracks The heating system can be set as needed. When connected to the computer, various test parameters can be displayed, recorded and printed. Experiments have shown that the center temperature curve of the coke cake of the JL-40 test coke oven is similar to the center temperature curve of the coke cake of the production coke oven.Vacuum brazing of ceramic and metal materials The JL-40 test coke oven is a relatively advanced coking research equipment. Its main function is to conduct coking tests by mixing various coals in a certain proportion according to the coal resources for coking and the quality requirements of the coke. The coal blending test is to: (1) find a coal supply base for the new coking plant and determine an economical and reasonable coal use plan; MIM metal injection molding sintering process (2) conduct coal quality identification of coal from newly put into operation and newly used coal, and evaluate its coking properties and its role in coal blending and coking in order to rationally utilize coking coal resources and expand the coking coal base; (3) adjust the production coal blending plan according to the coal supply situation to ensure coke quality; (4) inspect coking coal preparation and The effect of the new coking process.Vacuum Heat Treatment for Gear Manufacturing
Old 09-19-2023, 11:29 PM
917_Langheck's Avatar
Welcome aboard, scammer bot
Old 09-20-2023, 06:04 AM
JoeMag's Avatar
interesting that it shows joined May 2020. ...and when you go to it's home page it's a vacuum pump company based in China (Not the link in the post)
Old 09-20-2023, 09:11 AM
Ok, welcome aboard *sleeper* bot!
Old 09-20-2023, 06:39 PM
So why don’t the moderators bounce them?
Old 09-21-2023, 07:02 AM
Sportomatic 4 the People
crater64's Avatar
And here I was expecting a story about the Whittington brothers. Live and learn.
1970 911T Sporto coupe
2016 E350 4Matic Sport wagon
Old 09-22-2023, 06:13 AM
