-   -   Removal of Valve Spring Shims (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1146206-removal-valve-spring-shims.html)
RSOHC 09-12-2023 02:34 PM
I am having difficulty removing the shims under the valve spring seat for intake #6. The engine is in the car which is a 914/6. I have tried a magnet and brake cleaner.
I can see the shim turning. It appears that valve seal might be preventing the shim from being removed. Any ideas on removing the shims would be appreciated.
Lauran
dannobee 09-12-2023 02:56 PM
Remove the valve stem seal, then use the magnet and brake cleaner.
Depending on who made the seals, the OD is usually bigger than the ID of the shim.
RSOHC 09-12-2023 04:12 PM
What would be the process for removing the valve stem seal?
Lauran
gled49 09-12-2023 04:21 PM
No doubt you’re having difficulty, this is normally a bench job. Later engines had shims with a larger inside diameter that fit over the stem seals.
Henry Schmidt 09-12-2023 04:39 PM
Valve stem seal removing tool.... Less than $10 on Amazon
http://forums.pelicanparts.com/uploa...1694561844.jpg
http://forums.pelicanparts.com/uploa...1694561875.jpg
RSOHC 09-12-2023 04:45 PM
The inside diameter of the shims that were removed from exhaust #6 is 0.548 inches.
Pelican offers several brands of valve stem seals. Which brand should I order?
Lauran
RSOHC 09-12-2023 05:43 PM
Should I order the ElringKlinger valve stem seals?
Lauran
RSOHC 09-13-2023 05:19 AM
Would one of the 11 piece valve stem remover and installer tool kits sold on Amazon work for the installations of the valve stem seal?
RSOHC 09-13-2023 11:32 AM
I have ordered the valve stem seals from Porsche. The engine is a 1976 911S.
Lauran
Neil Harvey 09-14-2023 08:20 AM
My preference are the Viton not the Teflon types. Just my choice.
michaelmount123 09-14-2023 12:59 PM
If you have a valve spring shim that doesn't want to come out with a magnet, use compressed air and nozzle. Simply point the air nozzle near the OD of the shim, and ... poof, ezy-pezy.
BTW, the shims get stuck with hydraulic lock due to oil underneath them.
RSOHC 09-16-2023 12:58 PM
I am having problems removing the valve stem seals from intake #6.
The springs and seat haye been removed.
Any tips would be appreciated.
john walker's workshop 09-16-2023 01:54 PM
The brown ones can virtually bond themselves to the guide. The pictured tool doesn't stand a chance. They're hard to install also. White teflon is easy.
RSOHC 09-16-2023 02:08 PM
The existing seals are white. The tip of the pictured tool is not shaped properly. The serrations of the tool do not have contact with the seal.
RSOHC 09-17-2023 05:07 PM
The seal was removed with a modified seal puller tool.http://forums.pelicanparts.com/uploa...1694995636.jpg
RSOHC 09-21-2023 12:19 PM
The valve spring keepers are not releasing from the valve spring retainer with the spring compressed. How can I get the keepers to release from the valve spring retainer?
RSOHC 09-21-2023 04:26 PM
I am using a P7E valve spring compressor tool and 50 psi of compressed air to try to hold the valve in place. When I tighten the valve spring compressor tool I can hear air escaping in the valve area. The piston for the cylinder is at TDC.
dannobee 09-21-2023 05:37 PM
Tap the edge of the retainer with a brass drift and a hammer before you install the P7E, they'll free up.
RSOHC 09-21-2023 05:59 PM
I have tried the brass drift and it did not work.
RSOHC 09-22-2023 05:44 PM
The problem was solved by turning the retainer with a pair needle nose vise grips.
