-   -   Curil T on cylinder base gaskets timing (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1146290-curil-t-cylinder-base-gaskets-timing.html)
WYDBODY1986 09-14-2023 11:26 AM
I have a timing question for you all. If I install the pistons and cylinders with curil T on the base gaskets and tighten them down with hold downs and leave them till the next day I have a chance to install the heads and the cam housings will I have a problem with the Curil T?
Do I need to wait till I have a full day that I can get everything assembled and torqued from cylinders to cam housings?
Henry Schmidt 09-14-2023 04:44 PM
The purpose of using Curil T on base gaskets is the fact that it never hardens.
Cylinders on 911 air-cooled engine a constantly in flux (IE: moving from heat expansion and contraction) so a high temp, flexible sealant is best.
WYDBODY1986 09-14-2023 05:17 PM
Thank you Henry, I thought that was the case but I wanted to check to make sure. I’m finding that breaking the assembly of the engine down into stages has been helpful to keep me from feeling overwhelmed.
Brian
Martinlassmann 09-15-2023 10:55 AM
Hi Brian,
had the same issue 2 month ago.
The cams wouldn't fit well and after 1 night I could retourq Cyl 2 and 5. Then the cams fits perfect and now the engine runs and have no leaks
Martin
WYDBODY1986 09-15-2023 11:26 AM
Thanks Martin that is what I was hoping for
