-   -   Sleeve for leaking/grooved crank pulley snout Mezger engine. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1146611-sleeve-leaking-grooved-crank-pulley-snout-mezger-engine.html)
brnrdtns 09-20-2023 09:08 PM
I have a 01 Mezger engine with a grooved leaking pulley seal on the crank. I tried to change seals but it didn't work because of the groove I'm sure. What is the best sleeve to use? Any install advice? Thanks.
cgarr 09-21-2023 04:59 AM
Get a double lip seal so it rides on a different location
dannobee 09-21-2023 09:51 AM
Or see if you can find a Speedi-Sleeve that fits.
brnrdtns 09-21-2023 09:38 PM
Yah I was thinking a Speedisleeve type solution would be be best.
