Stahlwerks.com
Rod clearance on crank
I've looked and must be blind, but can't find the spec of what the tolerance of the rods moving side to side on the crank are.
I did a quick measure ment of the bearing journals and read 59.97 to 59.99, should be fine.
John Helgesen Stahlwerks.com restoration and cage design "Honest men know that revenge does not taste sweet" |
Author of "101 Projects"
Side clearances are what you are looking for. I think this info is in my book, but I don't have it next to me right now...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Stahlwerks.com
Got my magnifying glass out, is it the clearance (rod/sidewall) .200 -.350?
This must be a 3 liter crank as you didn't specify. The numbers you describe are for the main journals. According to a spec book, the standard main journal range is 59.971 - 59.990 mm. Your crank is 59.97 to 59.99 mm.
The connecting rod journal OD should be 52.971 - 52.990 mm (standard). The factory manuals don't list a rod side clearance that's readily obvious, but I think (please verify) it should be in the area of around 0.012 - 0.015" or thereabouts. Maybe Wayne has that info. "Got my magnifying glass out, is it the clearance (rod/sidewall) .200 -.350?" That's 0.008" - 0.013". That sounds about right. You eyeballed that? You're good. Sherwood Lee http://members.rennlist.org/911pcars |
I think he meant magnifying glass to read the very small print in the back of my book (it was the only way to make it fit!).
The rod / sidewall clearances are listed for all crankshafts on page 205. That's correct - +0.200 to +0.350, I believe I got that either from the factory manuals or the spec books. -Wayne
Stahlwerks.com
Yep, real small print.
Banned
Only comment fot those of us over 40 years old, WHAT PRINT? YOu mean theres print on those pages? The only genuine criticism of the book I could come up with.
Had to be done to fit into my print page budget, sorry...
-Wayne
