Banned
Drying oven operating procedures
1. Check whether there is any debris blocking the air inlet of the drying box and ensure smooth ventilation. 2. Check whether there is residual temperature in the drying box. If there is residual temperature, wait for cooling before operating.Vacuum heat treatment of carburized steel parts 3. Check the drying box for damage and defects, and whether the base and the bottom of the machine are balanced. Steps for usage: 1. Place the items that need to be dried in the drying box.Vacuum Heat Treating Small Parts 2. Turn on the temperature controller and set the desired temperature on the temperature controller. 3. Set the time as needed and open the drying oven. 4. Close the drying oven door.Vacuum heat treatment quality inspection 5. Pay attention to the temperature and humidity readings. If they exceed the set parameter range, please make adjustments in time.What's the vacuum brazing for diamond tools
Old 10-17-2023, 11:38 PM
This guy again? Dry up and blow away.
Old 10-18-2023, 04:49 PM
