Valve Adjusters Tip Damage
Anyone ever seen this?
Old 10-15-2023, 09:58 AM
Yes, replace it. If it won’t screw down, unscrew it until it pops the swivel off. The threads stretch and can get real hard to move. Chase the threads if necessary.
Old 10-15-2023, 10:46 AM
It isn’t stuck it the rocker, I was cleaning, inspecting, and assembling the rockers during my current overhaul. I’m trying to figure out what happened. Car is fairly new to me. Definitely replacing.
Old 10-15-2023, 01:02 PM
It's a 914 ...
stownsen914's Avatar
Almost looks like something tried to pry the swivel foot off the shank by applying force at an angle, and bent the lip outward like that. I guess that wouldn't be part of normal operation though.
Old 10-15-2023, 01:48 PM
PCA Member since 1988
I can't see how that would happen in normal operation, so I would guess it was damaged during removal or installation or some such.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-15-2023, 02:32 PM
An over rev can do that. It usually leaves pecker tracks on the valve stem end.
Old 10-15-2023, 02:40 PM
I can sorta see that possibility. But if the engine was over revved enough to cause the valves to float that far off their seats, they would have hit the pistons, which would have prevented them from going far enough to bend the feet. So it seems to me.
Old 10-15-2023, 03:12 PM
A little valve float, bounce, not enough to break the rocker or real valve to piston contact, but enough for the swivel foot to hit the valve stem on its edge. It leaves little tracks on the valve stem. This is the best I have but have seen lots worse. Blow the image up and look for the littles straight lines on the stem. Pix don’t come thru very well. Anyway just a thought.
Old 10-15-2023, 07:27 PM
Hmmm. I'll think about it some more.
Old 10-16-2023, 12:23 AM
Definitely man made ... ( not that i've done it ) !!!
Old 10-16-2023, 09:27 AM
Anyone measured the free play on the tip/screw junction? I thinking two were damaged, and 10 others my have been subjected.
Old 10-16-2023, 09:50 PM
I think i’ll order all new ones.
Old 10-17-2023, 01:09 PM
