hipdoc's Avatar
74’ 911 ignition
I’m trying to wire a MSD 6A ignition on my 911S. The prior owner took out the CD box. Was wondering what is this (see photo) and do I need it for MSD?
Thanks, Alan
Old 10-21-2023, 08:36 PM
PCA Member since 1988
No photo.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 10-21-2023, 11:08 PM
hipdoc's Avatar
Old 10-22-2023, 08:55 AM
That's a capacitor for RF ignition noise suppression. You can usually remove it with no ill effects because modern radios do a much better job of suppressing ignition noise than 1970's radios. Of course, try running with and without it to be sure it doesn't have some effect on your MSD.
Old 10-22-2023, 02:48 PM
