Banned
Sc 3.0 engine
3.0sc engine on the test stand, I now realise that I made the stand too tall!! Need to cut it down 6 inches. Or I need to grow 6 inches??
Afr seems good. Just need to double check warm and cold control pressures and hopefully call it done.
Old 11-17-2023, 06:46 AM
PCA Member since 1988
I vote for high heels. Then post a picture of yourself in spikes working on your engine! We'll make sure it goes viral.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 11-17-2023, 11:45 AM
Senior Member
My vote is for KISS boots
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 11-18-2023, 07:33 AM
Even better!
Old 11-18-2023, 11:55 AM
