EFI injector size
Was wondering what size injectors people are using on a 3.5L with ITB’s and EFI. Looking to support 100 HP per liter
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
To support 350HP, you'll need 175 lbs per hr of fuel, assumming a .50 BSFC (Brake Specific Fuel Consumption. A .50 BSFC is consider average for a performance N/A engine.
So, 175/6 (6 cylinders) is 30 lbs per hr per cylinder. Mind you, this leaves no head room.
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
Navin Johnson
Use a calculator like this for find what size injectors you need..
Injector sizing calculator https://www.injector.com/cart/pc/Bosch-36-lb-hr-380-cc-min-Fuel-Injector-44p40.htm"]36# injectors[/URL]
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 10-27-2023 at 12:28 PM.. |
Yes, 400cc and over. Get some modern Bosch motorsport injectors that are stainless and compatible with ethanol (e85). Too big is not really a problem.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Thanks all.
Racer
I recommend talking with Injector Dynamics. They have the best product on the market...
Injector Dynamics
Scott Winders PCA GT3 #3 2021 & 2022 PCA GT3 National Champion 2021 & 2022 PCA West Coast Series GT3 Champion |
Based on their website they sell Bosch injectors. Great products.
There are other very high end options available as well. We have had great results with https://deatschwerks.com/en-ca/collections/injectors as well on varying motors. Same with their pumps. YMMV
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Racer
"The ID1050x is the evolution of the ID1000, and the latest addition to the X-Series. It is the most recent offering from the partnership of Injector Dynamics and Bosch Motorsport, and is the result of lessons learned during development of the ID1300x, and ID1700x. Like the ID1300x and ID1700x, the ID1050x is not a modified production component. It is a built to spec motorsport injector, offering optimization of critical operating parameters important to you, the motorsport tuner. "
Thanks again everyone my problem is the injector I want to use only comes is 100pph or higher. My issue is the minimum pulse of it is to much for idle. Too much fuel delivered to fun smooth. I will most likely end up with a 48pph LS short size EV14 connector. Over kill. But
Navin Johnson
You never mentioned if you need a high or low impedance injector... The controls on modern EFI systems can handle idle on over sized injectors
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I am looking to kind of limit the flow so I was looking at high impedance. Plus high should run cooler. I am using Hal tech 750 ecu iac tp iat map and dual o2. Plus the 750 has a barometer. I understand that the system compensates a lot of factors for smooth idle. But if the minimum pulse of the injector is to much it will run too rich
Lots of people runs double that on small 4 bangers. Good injectors, a good EFI and accurate specs on the injectors in the EFI. But its really unnecessary, to run bigger injectors than you need. There are a myriad of injectors that will suit your needs. High impedance or low has nothing to do with flow, its mostly old tech and new tech. You need low impedance injectors when you are going really crazy.
