Banned
Cams
I’m ordering 911 E cams for a 1973 911 T with 2.4 L and MFI. Got them from AA Performance. Been trying to find the specs to confirm a question they asked.
I ordered the WC—05-082 and they asked if we needed 47mm or 49mm. After a little research, it looked like 47mm is the journal size for up to 2.7L engines. So that’s what I told them. I thought I would ask here and see if anyone can confirm. I’ve tried searching through this group and on the web, but it’s hard to find this info. Or maybe I just don’t know where to look.
Thanks in advance for any assistance you can lend.
Old 11-20-2023, 03:39 PM
If the cam towers are original to the motor, they are definitely 47mm. They are also 47mm if they only have 3 bearing journals in the cam tower. Also not hard to measure the diameter of the bore to confirm.
Sent from my SM-G991U using Tapatalk
Old 11-20-2023, 04:35 PM
Navin Johnson
TimT's Avatar
This is Spamtastic...
'69 911 GT-5
'75 914 GT-3
and others
Old 11-20-2023, 05:01 PM
Post
Check post a few below…. Samevposter.
Setting cam timing that haven’t even been ordered.
Odd stuff
TOT
Old 11-20-2023, 05:59 PM
It's a 914 ...
stownsen914's Avatar
That would be a lot of research for a spam post, just sayin'. Standing by ...
Old 11-21-2023, 05:16 AM
Posts
You are correct…..when coupled with other post it’s odd but 2 poster. We may all have become too careful or not. [img]http:
TOT
Old 11-21-2023, 05:46 AM
