Certified Pre-Owned
BGCarrera32's Avatar
Which cylinder base gaskets should I go with here?
Hi guys:
Deck height question here (regarding top edge of piston at TDC to top of cylinder)...doing a pretty straight up rebuild on a 3.2 Carrera motor using new Mahle 10.3:1 Euro/ROW pistons in 95mm jugs as opposed to the US 9.5:1. It's a compression bump, that's it. Case has not been decked or machined.
For checking "deck height":
Dropped a P and C on #4 with a .25 mm stock base gasket thickness.
Dropped a P and C on #1 with a .50 mm gasket thickness.
For the .25 mm gasket measuring 3 places around the piston it is averaging .96 mm with some repeat measurements returning at 1.08 to 1.28 mm.
For the .50 mm gasket measuring 3 places around the piston, I'm seeing a deck height average of 1.19, with tries reading 1.21 to 1.53.
Obviously, this assumes my measuring is decent, so let's say it is.
My rebuilt heads have had .004" (.10mm) removed . Will perform a valve clearance check, etc.
Question here is which gasket to go with? In understand factory was .25mm, again no case machining done. I want to make sure I'm not leaving power (compression) off the table. What do you think- what would you do?
BG
With .25 mm gasket:
'84 Carrera Coupe
Old 12-15-2023, 08:50 PM
PCA Member since 1988
My view: With 1mm deck clearance, that's plenty. Use the .25mm base gasket. I eliminated my base gasket in order to get deck clearance down to .030"/.75mm on my current 3.2 long-stroke engine. I like to keep the combustion chamber tight, not so much for the increase in CR (which is pretty small for just .25mm change in deck clearance), but to improve combustion chamber squish and turbulence.
But, I also measured the point where the piston contacted the inside of the head, to make sure I had at least .75mm there too. There are several ways to do that--use clay, a piece of solder, or assemble piston to cylinder and set the piston deck clearance at 1mm, then put the piston/cylinder on the head and measure how much further you can push it into the cylinder before it touches the head. In my case using the same Mahle Sport P/C's you have, my clearance to the head was the same as the deck clearance, .75mm.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 12-15-2023, 11:31 PM
Certified Pre-Owned
Thanks. A few more data points as I had some time tonight; I did the solder method and using the .25 mm gasket installed, I placed my solder on what appears to be the highest spot of the dome and a spot across from it. The solder was around 2.5 mm unsquished. When I rotated the engine over twice, it didn't squish at all.
I then moved the solder to a couple of alternate spots, just for giggles, and in one spot it did squish. When I removed it measured 1.21 mm. I think this is confirming that the .25 mm gasket is good to go.
Also, and I've run into this before, I am getting these striations on the cylinder wall when turning the engine over. They don't feel like scratches when hitting them with my fingernail, but I can't wipe them away either. I took great pains to ensure eveything was clean, rings were deburred as necessary, etc. and have plenty of Joe Gibbs break-in oil lubing the Ps and C's. Have you run into this before as well or am I overthinking it? Again, they look like scratches but not really feeling anything and nothing is binding when I turn the engine over by hand. How do I mitigate or avoid this?
'84 Carrera Coupe
Old 12-16-2023, 08:48 PM
Those vertical lines are normal. That's the rings starting to wear against the cylinder walls.
Old 12-16-2023, 11:43 PM
Def use the 0.25 gaskets.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 12-17-2023, 04:05 AM
Certified Pre-Owned
Thanks guys
'84 Carrera Coupe
Old 12-17-2023, 07:51 PM
Jeff Alton's Avatar
Good Advice already given!
Cheers
www.turn3autosport.com
Old 12-17-2023, 10:39 PM
