964 Oil Pump Torque
Hi
I disassembled and cleaned the gears of the oil pump. Does anyone know the torque spec for the 4 nuts holding the pump housing together. Do i use loctite as well?
Also what is the torque specs for the oil pump onto the case? with loctite?
thanks in advance.
Old 12-06-2023, 04:36 PM
Porsche recommends 50 inch/lbs for a 6mm fastener , and yes red Loctite , I have seen loose nuts .
Old 12-07-2023, 08:00 PM
JoeMag's Avatar
...is that 6mm torque spec just for the oil pump housing bolts? ...typical spec for 6mm fastener is 9.7 nm, 7 ft-lbs, 84 inch-lbs.
As far as oil pump to case, they're M8's at 23nm or 17 ft-lbs. Use lock nut 999 084 095 02
Old 12-11-2023, 09:59 AM
I’m with Joe, i torque all 6mm hardware to 10nm
Old 12-11-2023, 01:52 PM
I asked Porsche many years ago when I bought the new Turbo pump going in my 3.4.
They said 50 inch-pounds with red loctite (270 is the number they quoted).
I am presuming that the 964 pump is not that much different....
D.
Old 12-12-2023, 12:12 PM
