-   -   Replacing damaged heads 2.7 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/115251-replacing-damaged-heads-2-7-a.html)
farleyd 06-17-2003 11:11 AM
Hi to all, 2 of my 2.7S heads are cracked around valve bosses. I have two spare heads but they are slightly different. Same part number but the surface that mates with the cylinder head is even/flat, while the 4 original heads have a elevated surface sitting around the studs.
Any clue? Can i use them anyhow?
Thanks!
