What Vendor can drill and cross drill camshafts for internal lubricaiton (center lube
Hi engine builders, do you know of anyone that can modify camshafts to have center lube cams? Webcam said they've had a few customers use a gun shop to bore it and then another shop to do the cross drill, but is there anyone abroad that does this or a more efficient way?
Old 01-03-2024, 08:01 PM
Behind the Sun
Why do you think you need your cams drilled?
If Porsche abandoned this technique decades ago.....
I don't who does it. Just asking an honest question.
Old 01-04-2024, 06:16 AM
Constitutional Liberal
Turbo_pro's Avatar
What you are looking for is a machine shop that does gun drilling.
Cold cast is relatively soft so you won't need special tooling.
Jim
“Rhetoric is no substitute for reality.”
― Thomas Sowell
Old 01-04-2024, 09:05 AM
Paul Shugert's Avatar
I would like to know who can perform this drilling also. My car has Solex center lube cams that are NLA from,Porsche.
Old 01-05-2024, 10:04 AM
The team at WebCam knows a source that can gun drill. I didn't ask for the source since I found some cams pre-drilled. If you're interested call them and they'll give you their machinist that's local in SoCal.
Old 01-06-2024, 04:45 PM
Senior Member
Cold cast is soft but drill bits can wander a bit compared to other metals. Edm would be a better choice.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 01-07-2024, 06:19 AM
