Porsche exploited the natural frequency of a carefully designed mounting bracket for the knock sensor starting on the 964. By cleverly designing a bracket with a specific natural frequency, they could determine WHICH CYLINDER IS KNOCKING.
As you can see in this graph of cylinder pressure vs crank angle, knock occurs over a fairly small window of crank angle. With a knowledge of the engine position from the cam sensor, the knock signal can be corelated to a specific cylinder! http://forums.pelicanparts.com/uploa...1704856804.jpg If your system is not capable of individual cylinder knock detection in a reliable way, the mounting bracket is of no use, so you would be better off mounting the sensor to the block. So there is that. |
Interesting comment on "not" using the mounting bridge. My ecu (ol' motec M48), does not have knock capability, however, I have external "listening device" (need to look at what I have), and have the knock sensors on the two bridges going into the listening device.
Would I be better off to put the knock sensors directly on cyl 2 and 5's bosses that the bridge bolts on to? |
| All times are GMT -8. The time now is 07:30 PM. |
