911SC 3.0 Rebuild and Upgrade
I purchased a 1981 SC back in May and absolutely love it. It’s seen far more use than my hotrod 1972 T with it essentially being my daily, plus I can take my two monkeys and wife around in it! With that said, it consumes about a quart of oil every 600 miles so it seems a refresh is due, which is corroborated by my mechanic having looked it over.
Now I considered simply just rebuilding it and leaving it stock, but I really enjoy this car and would love to get around 250-275hp. I was told it’d be roughly $15k for just a rebuild and in order to hit somewhere around the numbers I’m looking for I’d be all in for $30-35k. Parts and options we discussed are listed below: EFI - Bitzracing, X-Factory, Clewett being some options GE80 camshafts 98mm Mahle pistons 74.4mm crank and 23mm wrist pins Heads port and polish Bore case J&B dual plug distributor I know this might not be the most efficient use of funds, some might argue sell it and buy a car with the upgrades you already want, but with the addition of an IROC front and RS rear bumper, she’ll look exactly as I want. So what am I missing? I plan on taking time off work to assist with all the tear down, reassembly, and reinstall and finishing Dempsey’s “Porsche 911 Engines” and Anderson’s “Porsche 911 Performance Handbook” before the process commences. Any recommendations? And I have read the “3.0 to 275hp” thread three times! Thanks! ![]() ![]() ![]()
"Purists are the Karens of motorsports. IG - Iron_Dad_Moto 1972 Porsche 911 - Long Term Project. 3.6TT/G96.50 1981 Porsche 911SC - In Progress. F/A-18C/D, F-15C, F-35B/C |
Your not going to get 275hp out of a 3.0.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind. |
Heads up, your oil consumption is 65% of the average oil consumption specified in the Porsche published technical specifications including later revisions. Here is the 1981 revision of the technical spec.
Your oil consumption is not cause for rebuild, with alusil cylinder most likely, you are in a very strong position to continue almost indefinitely without rate of consumption increasing. Unless you see smoke coming out the back on decel, I'd look for other reasons to have a rebuild.
81 SC. 930/16 (us model) Last edited by ahh911; 12-22-2023 at 07:03 AM.. |
I agree with the above posts. Do a leak down and compression check, and if all is within normal range just drive it ! No way you will get 270hp out of a 3.0 unless you increase CR and run race headers and exhaust. You're in CA , the CARB police will be all over you.
'77 1973 911RS Backdate, 2.7 liter w/webers '70 911ST , 3.2 liter '82 '74 911 IROC Tribute , 3.0 in progress '75 911 RSR street car in progress '77 930 Replica '75 993 GT2 EVO race car , 3.6 TT '79 928 5 speed money pit in progress |
Add HP to the '72. You can do whatever you want on that one, it's smog exempt , plus add rear seats for the monkeys.
Thanks all for the advice.
“…so it seems a refresh is due, which is corroborated by my mechanic having looked it over…”
Might ask your mechanic how he arrived at his conclusion. If you didn’t explicitly ask to rebuild, he seems pretty willing to tear into what you’ve represented here as a healthy motor.
Ass-engine Nazi slot car -- PJ O'Rourke |
If you're looking to re-build, then broken head studs will probably be the reason. That would be a fortunate scenario in my opinion, it likely means the engine has never been disassembled.
I had 2 headstuds broken when purchased, rebuilt it myself and decided that putting a well running engine back together and enjoying the power band as it left the factory was what made most sense. Certainly giving up low end torque would be out of the question for me then and now, but I've been reading about the M1 cams. Ian C, claims it provides the factory low end torque with some high end extension with some fueling tweaks. Looking back, that would have been the best choice. Initially I'd run the stock cis up to factory redline with the m1 until I'd learn how to operate the cis, then start playing with the fueling once everything was well in hand. The cam would presumably be waiting for me to catch up to it. Too late now. Phil
81 SC. 930/16 (us model) Last edited by ahh911; 12-25-2023 at 12:39 PM.. |
Rather then seek HP, look for weight reduction. Lots of threads on here on the way to go.
Bumping to 3.4, port/polish, EFI and cams would yield 275hp easily if tuned correctly.
I'd avoid the weight reduction aspect for a daily. You already have a '72 hotrod; keep the impact bumpers and interior (sound deadening). I'd focus on torque over an outright HP figure. Power under the curve makes the car better in traffic.
-Tony Instagram: @Pablo_the_Porsche | @RuchlosRallye AchtungKraft #002 |
I'm looking at other options, I don't want the 81 to be a super lightweight outlaw, maybe more of an in-law to quote a buddy.
Going to look at a 3.6 Varioram this afternoon which might be best to increase power and keep the streetable aspect of the car. Not in a rush but I do appreciate all the opinions.
PCA Member since 1988
Like pocv0 wrote, since you already have a 1972 hotrod, throw your fun money at that one. If money is not a big deal and you want more oomph out of the 1981, then "there's no replacement for displacement." A 3.6 Varioram probably is the best of all options. Just be sure to get the whole package, from the ECM and wiring harness all the way to the exhaust tips. You will satisfy both your right foot and the CARB nannies. Any attempt to get to 275 HP based on a 3.0 case and crank will require a much hotter cam, which almost certainly will cause you grief at smog check time. It will also make the car less satisfying on the street.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
I agree with the others. Check headstands and do a LD test and drive it.
That said, Id prefer a hopped up 3.0 over a 3.6 Although both are expensive endeavors rebuilding the original 3.0 would be cheaper, better ROI and more fun IMO Minor thread derail question. Can you please post pics and specs of the 400HP 72
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
996T brakes 12 point cage 930LSD Coilover suspension 11/13” wide wheels F/R ![]() ![]()
If I were to purchase the engine below, anyone have a rough parts list of additional items I'd need to make it work in my SC? I've read through countless SC to Varioram conversion threads, and know that there use to be kits available, but having a hard time finding a source listing everything to make it function properly.
Porsche 993 Varioram Engine 3.8 litre
you would need a standalone EFI system I guess, 915 flywheel conversion from patrick motorsports, powersteering delete and some other bits and bobs....
3.6 or 3.8 in a G body is the way =D
My worst fear is that when I die, my wife will sell my cars for what I told her I paid for them |
At some point, app 2yrs ago I decided to add one 600ml bottle of Lubro Moly Mos2 at each oil change and can say that I've not noticed any blue smoke at start up. I'm not saying it's related but I thought I should point it out to you. I currently have 210K mi and I'm using (leaking) app 1 L per 1000 mi. |
