930 torque case bolts/main bearing clearance
1. what is the torque for the thru case bolts on the 930 3.3. I noticed there is 25ftlbs for earlier 911 cases and 37ftlbs for later 964 cases?
2. What is the torque pattern? . I have a 964 workshop manual and its different then what wayne has in his book. 3. I did a plastigauge check on the mains and it came out about .076-- maybe a couple even slightly looser. Specs according to waynes book is .010-.072. this was at 25ftlbs. Is this a serious issue.. or i should be fine. I had good oil pressure before the rebuild and using same size bearings. thanks in advance |
