-   -   Case seam damage (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1154108-case-seam-damage.html)
JW2000 01-18-2024 06:29 PM
Case seam damage
So I have some damage on the seam about 6 inches near the bottom oil pump cover.
its on the outer edge of the seam.. Raised up about less than 1mm. It appears its from people jacking up the car from the engine.
1. Do I get a flat metal block with sandpaper and just sand the edge down on both cases... If so what grit sand paper? should i also block the entire case with sand paper as well?
or
Do i leaven it alone?....thinking even though the seam got dented, both sides of the case dented together which would make me think they would fit back in together.?
thanks
snbush67 01-18-2024 06:43 PM
I’m having difficulty visualizing from the description. I think a picture might help. Is the case apart? The mating surface must be flat.
JW2000 01-18-2024 07:14 PM
http://forums.pelicanparts.com/uploa...1705633781.jpg
http://forums.pelicanparts.com/uploa...1705633781.png
Or do I hammer it smooth .?
.both halves have it. so If one side is up, the the other side of the case must be bent down since it probally happened with the case bolted from a jack. Just on the edge. Which has me wondering do I leave it alone and it will fit back like a puzzle. ?
Flat6pac 01-19-2024 04:00 AM
I would leave it alone as you’ll likely do more damage.
I would reassemble and seal with threebond, yamabond, because of the sealing qualities of the sealant and the thickness of the sealant would forgive the damage.
Bruce
safe 01-19-2024 07:14 AM
Remove raised highspots. Sealer might fix scratches and lowspots, but high spots are not good.
A fine file and light pressure. A file is a marvelous tool, on a flat surface it does almost nothing, any raised part it will remove.
What kind of case? A mag case would most likely need machine work in other places.
rudedude 01-19-2024 08:33 AM
I wouldn't trust your punch as a straightedge
pocv0 01-19-2024 09:06 AM
File the high spots off on both sides, and as others have mentioned, Yamabond, RPV or similar sealant you'll be fine. Don't use the factory Loctite sealant.
Castro911s 02-08-2024 08:15 PM
Yeah use a straight edge.
