-   -   Rod bolt part numbers (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1154276-rod-bolt-part-numbers.html)
RockhillMTR 01-21-2024 11:53 AM
Can someone tell me what the correct part numbers are for both 2.0 and 2.2 rod bolts?
As I'm researching parts im getting confused on which are which.
Also, are the 2.2 rod bolts the same as 2.4-2.7 bolts?
Henry Schmidt 01-21-2024 12:40 PM
All 2.0-3.0 rod bolts are 10mm. They are however, different lengths.
901 103 172 00 2.0 64-69 911, 69-71 914/6 Short
901 103 171 02 2.2 70-71 911 long
914 103 171 01 2.4, 2.7. 3.0 72-83 911 medium
Fun fact: ARP never made 2.2 rod bolts. To upgrade to ARP you simply machine the rod cap to fit the 2.4/2.7 rod bolts.
RockhillMTR 01-21-2024 01:01 PM
Thank you Henry!
