It's a 914 ...
stownsen914's Avatar
Intermediate shaft bearings - Glyco quality?
Are intermediate shaft bearings from Glyco problematic like rod bearings? I recall that Glyco main bearings haven't had the issues that rod bearings have, but intermediate shaft bearings get more beaten up than crank mains. What say ye?
Old 01-24-2024, 08:50 PM
PCA Member since 1988
Follow this thread too:
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1154543-intermediate-shaft-fitment.html
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-24-2024, 09:53 PM
The race engine builders here can provide more definitive responses. I doubt it makes any difference in a street engine, and Bruce Anderson's book advises against it. Nevertheless, I cleaned up the casting roughness in the intake and exhaust ports and rounded off the edges of the guide support bosses. Just because.
I swear it makes another 0.15 HP!!!
Old 01-26-2024, 11:27 AM
Jeff Alton's Avatar
Have not had an issue with Glyco intermediate shaft bearings, to the point we always have between 6-10 sets in stock for future builds, as at one time, they were hard to find.
Cheers
www.turn3autosport.com
Old 01-27-2024, 06:35 PM
Cheers
Thanks Jeff, it’s great to have feedback.
Old 01-27-2024, 07:02 PM
Finally they are more easily available.
Old 02-08-2024, 08:18 PM
DIY wrencher
Just FYI original Porsche IMS bearings are also not very expensive, if I recall it was around €50 for the set or so?
Given that these bearings usually wear quite a bit faster than rod and main ones, I bought original for piece of mind.
88 911 Carrera 3.2 G50 - driver
77 911S - rust bucket backdate project
IG: @lukas.matzinger
Old 02-19-2024, 02:47 PM
Jeff Alton's Avatar
EVERY motor we have ever openned up had worn PORSCHE intermediate shaft bearings... Copper on all of them.... Porsche does not make the bearing. They buy it from someone....
Much like the oil filters we buy direct from Porsche....
Cheers
Old 02-28-2024, 10:13 PM
