abit off center
cgarr's Avatar
Valve guide damage
Working on a set of heads with fairly new guides and see this damage on the inside bores. What would cause this? Improper install, reamer, honing? They did reuse the original valves
Craig
______________________
Craig
G2Performance
Old 02-01-2024, 09:39 AM
Maybe a burr on the valve keeper grooves and someone was twisting the valve out?
Old 02-01-2024, 09:42 AM
Or the rings and ridges are on purpose the "tighten up" a loose guide for a few more miles with out replacement, ie MotorMiester head rebuild.
I'm not picking my nose..I'm porting my upper intake manifold.
Old 02-01-2024, 01:32 PM
PCA Member since 1988
Likely. Knurling the valve guides to tighten them up was common in the days of cast iron heads without replaceable guides. In old school engines, it worked well enough. When the head was rebuilt, the guides could be knurled if they weren't worn out, or bored oversize and oversize valves installed, or bored out and new guides pressed in.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-01-2024, 01:49 PM
If it's spiral, maybe the reamer had a burr.
206 637 4071
Old 02-01-2024, 05:43 PM
Looks like they used a standard machinists reamer which is only suppose to travel in one direction IN and they used it IN and Out like a brush hone.
We are dominated by the relatively small number of persons who understand the mental processes and social patterns of the masses. It is they who pull the wires which control the public mind.
Old 02-02-2024, 06:53 AM
