Porsche was pretty stingy when it came to the Cayenne oil consumption issue. A friend (working at a Porsche dealer at the time) had the same problem, Porsche rejected his request for assistance and he ended up sourcing a low mileage replacement. |
With the old engine, it was burning so much oil it would foul one of the spark plugs in a few hundred miles.
Even with a new V8 engine, it used a liter of oil per 1000 miles, which was "within specs" as far as Porsche was concerned. And, yes, after a few years it became evident that they had a lot of failures due to Alusil cylinders. There is/was a company that would rebuild those engines by boring and installing cast iron liners for a fraction of what a new or rebuilt engine from Porsche would cost. That would have been my fall-back plan. FYI, my Ford GT has an aluminum block, but it uses cast iron cylinder liners too. Often, the old tech is still the best. |
Back to the original post : Why not get a good used 3.3 pistons and cylinders, nice and clean ones are everywhere and can ge bought for less than $1K. Thats what I did when I converted my 3.2 to 3.3 low compression. |
| All times are GMT -8. The time now is 01:45 PM. |
