Banned
Distributor
Hi mate, how much is the price for 911 fuel distributor?
Old 02-09-2024, 07:30 AM
E Sully's Avatar
Prices can range quite a bit. I've found some good used ones for $100, up to $500 range for a very nice rebuilt.
Searching the Used Parts forum might turn some up, or you could post a wanted to buy ad there.
Ed
1973.5 T
Old 02-10-2024, 08:35 AM
PCA Member since 1988
Make sure you get the part number for your car. Look on the plate on your FD.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 02-11-2024, 12:54 AM
Dist
Just priced a rebuild on my 77 it was 800.00
Old 02-11-2024, 05:19 AM
E Sully's Avatar
If you have a fuel distributor, rebuild kits are available. I have done a few with cis-jetronic.
https://cis-jetronic.com/index.php?rt=product/manufacturer&manufacturer_id=34
Some use kits from salvox
https://salvox.com/
Other options.
https://specialtauto.com/node/6
Ed
1973.5 T
Old 02-11-2024, 06:23 AM
